Newb Question
valkyrie00
I will be connecting an Emotiva XPA 5 amp to a Denon 3313 Ci receiver. I will be powering all channels except the 2 rear speakers in a 7.1 setup through the Emotiva. The Denon will drive the two rear speakers. My question is: Is there only one RCA cable for each speaker from the receiver to the amp? I now this is rudimentary for all of you but I'm trying to get this right before the equipment arrives and I am a complete newb at this. Thanks for the help!
Also is there only one end on the cable for the amp and the receiver? Can you recommend some good RCA cable...?
Polk Audio RtiA9 - Front x 2
Polk Audio CsiA6 - Center
Polk Audio FXiA6 - Surrounds x 4
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Each channel will only need one RCA cable from teh Denon to the Emo.
As far as "good"RCA cables it depends on budget and desire.
You want to pay $10 each? $100 each? $1,000 each?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Add another 0 and get a decent cable !!!!If you can't hear a difference, don't waste your money.
Thanks brgman. I guess I want the most for my money. Not spending $1,000. I've read some who swear by the most expensive cabling and some who swear it doesn't matter as long as it meets industry standards. As stated, I am a complete newb but it seems logical to me that as long as RCA cables have been out they should have about the same performance. As long as they're in good condition etc. I am a complete newb though... Someone suggested Blue Jeans cable...Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD -
I have heard good things about BJ and i'm sure some will pipe in about others.
Pepster on here makes nice cables for a great price if you want bang for the buck simple.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I use Blue Jeans cable for my amp to prepro and Monoprice for my subs all work just fine.
http://www.bluejeanscable.com/store/audio/index.htm
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021814&p_id=2864&seq=1&format=2
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2680&seq=1&format=2
Good cable, reasonable prices.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Dont know about the highemd cables but have learned that you cant beat a BJ.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
soundfreak1 wrote: »Dont know about the highemd cables but have learned that you cant beat a BJ.
Lol...unjacketed are the best! -
For your needs, the inexpensive cables are fine. The more expensive cables are for after you develop an ear for nuances, and want to try and extract every bit of music from the source. Some people never develop the ability to hear nuances so they try and convince others those nuances do not exist. Pay no attention to those people behind the curtain. Before getting better cable you will be upgrading your gear first. Then you can start to worry about cables, power cords, vibration elimination, etc.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
valkyrie00 wrote: »I will be connecting an Emotiva XPA 5 amp to a Denon 3313 Ci receiver. I will be powering all channels except the 2 rear speakers in a 7.1 setup through the Emotiva. The Denon will drive the two rear speakers. My question is: Is there only one RCA cable for each speaker from the receiver to the amp? I now this is rudimentary for all of you but I'm trying to get this right before the equipment arrives and I am a complete newb at this. Thanks for the help!
I use Emotiva X-series cables and they are great. These are on sale until 01/15/13. Hurry.
http://shop.emotiva.com/collections/interconnects/products/xvrcaProcessor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub -
Valkyrie, a coaxial cable with an RCA plug on each end is used. For several years I've used these cables in various lengths. They do this very simple job as well as it can be done and there's no good reason to pay more.
Wrong!!!Political Correctness'.........defined
President of Club Polk -
Spend a little more money and buy something like Signal Cable Analog 1 or 2's, or Audioquest Sidewinders.
+1 Bluejeans cable.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
