need input - no pun intended...
valkyrie00
I have a Denon AVR 3313 Ci receiver and a Emotiva XPA 5. My question is what speakers should I run through the Emotiva? I was thinking initially about running my front RTi A9's through the Emotiva and the rest of my 7.1 channels through the receiver. Any best practices??
Polk Audio RtiA9 - Front x 2
Polk Audio CsiA6 - Center
Polk Audio FXiA6 - Surrounds x 4
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Post edited by valkyrie00 on
The Emotiva is a dedicated 5 channel amp...I'd run all 5 speakers thru this.
+1 Front, center and surround.Erik Tracy wrote: »The Emotiva is a dedicated 5 channel amp...I'd run all 5 speakers thru this. -
Another vote for Front, Center and Surround.
XPA 5 channels. I have 7 speakers in my setup. Are you saying to run everything but the fronts through the XPA 5?Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD -
not so much, fronts are bigger speakers and will benefit and add more to your system with more power,2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
valkyrie00 wrote: »XPA 5 channels. I have 7 speakers in my setup. Are you saying to run everything but the fronts through the XPA 5?
Welcome to Club Polk!
No! You run "everything, including the front L/C/R channels, and the two surrounds with the Emotiva". And leave the TWO SURROUND BACKS to the Denon.
The FRONTS are what need the Emotiva the 'most'!
No. Amp the A9's, your certer speaker and 2 of your surrounds then let the reciever power the other 2.
