are SDA 2 speakers 4 OHM or 6 OHM ?
pglbook
pglbook Posts: 2,262
edited December 2012 in Speakers
Are Polk SDA 2 speakers rated at 4 OHM or 6 OHMs?
I thought they were 4 OHM speakers but recently heard someone mention that they are 6 OHM speakers.
I am getting a pair of SDA 2s and just want to make sure my Yamaha CR 2020 receiver will not have a problem powering the Polk SDA 2s. I currently have my CR 2020 running a set of Polk 10A speakers, which are 6 OHM speakers (later Monitor 10 series were 8 OHM but the Monitor 10A were 6 OHM) and the receiver does a wonderful job with them.
Please let me know if the SDA 2s are 4 OHM or 6 OHM?
And please let me know if you think my Yamaha CR 2020 will have any problem running the SDA 2 speakers.
Thanks so much. I am very excited to get a great pair of SDA 2s and just want to make sure my receiver is up to the task.
Take care. I hope all are fine and having a great Saturday. We are snowbound here in upstate NY.
Post edited by pglbook on
  • PolkieMan
    PolkieMan Posts: 2,446
    It's in the SDA Handbook. http://vr3mods.com/LCSDAUpgrade.php
    There is a lot of differences between the 2A and the 2B.
    One of them was to make the newer model more amplifier friendly by
    bumping up the resistance to 6 ohms improve power handling so that you
    didn't have to buy a $5000 amp to enjoy them, let's face it Polk was trying
    to sell products to people that could afford them.:lol:
  • billysam1
    billysam1 Posts: 9
    I just bought a pair of 2B,s yesterday and got the original intsruction manual with them .according to it they are 6 ohm .
  • billysam1
    billysam1 Posts: 9
    This is the 2nd pair of polks I have owned I had a pair of monitor 10,s a while back which I ran off a marantz 2250B with no problem and sounded very good . I have the SDA 2B,s running off a pioneer SX 1280 right now, 185 old school watts which I thought would be lots to drive these speakers but they seem to be sucking the power right out of this receiver .I previously had a pair of cerwin vega AT 15,s running off the same receiver at 4 ohms with no problem .so what gives here what does it take to drive these speakers
  • gdb
    gdb Posts: 6,012
    CVs are supposed to be very efficient IIRC, don't think that that's been said of the SDAs.
  • billysam1
    billysam1 Posts: 9
    yes your right, I was told this before I bought them .But I just had to try them anyway,s alway,s experimenting with speakers it,s a hobby .
    F1nut Posts: 51,793
    A good integrated or separates. Receivers are....well, just receivers.
  • billysam1
    billysam1 Posts: 9
    actually the more I listen to these speakers the more I like them, now I will have to look for a good power amp ,but the 1280 will have to do for now .
  • PolkieMan
    Yes you will, the longer you have them, the more you will like them, welcome to the rabbit hole:razz:
    billysam1 wrote: »
