Mdf
for the past 7 mths the sub had been sitting on the carpet with its lil rubber feet (202). This weekend I found 2 pieces of MDF painted them black and put them uner the sub. I found the sub to sound better can this be true or did is just hear the dif cause I wanted to hear a diff.??
Post edited by Willow on
This can be true. The sub has a slightly stronger base so it isn't moving around that much losing energy. A lot of people will use a concrete or marble slab to help the sound in this regard. Either of those should offer quite a bit more of the same type of improvement that you heard.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
I have a concrete step paver, the 16x16" thick ones painted balck and it works great.. keeps my wooden floors quiet..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
do you find it makes a difference ??
Yeah, it makes a difference.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Hey guys, thanks for the info. Never thought of that. Always thought my bass was a little lacking. I have to give that a try as well. (a piece of marble would look nice).Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
I thought marble as well my wife will say no more money on the damn stereo...... so I used some MDF i had lying around
