Mdf
edited May 2004 in Speakers
for the past 7 mths the sub had been sitting on the carpet with its lil rubber feet (202). This weekend I found 2 pieces of MDF painted them black and put them uner the sub. I found the sub to sound better can this be true or did is just hear the dif cause I wanted to hear a diff.??
Post edited by Willow on
Welcome!
    edited May 2004
    This can be true. The sub has a slightly stronger base so it isn't moving around that much losing energy. A lot of people will use a concrete or marble slab to help the sound in this regard. Either of those should offer quite a bit more of the same type of improvement that you heard.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
    edited May 2004
    I have a concrete step paver, the 16x16" thick ones painted balck and it works great.. keeps my wooden floors quiet..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    edited May 2004
    do you find it makes a difference ??
    edited May 2004
    Yeah, it makes a difference.
    "God grooves with tubes."
    edited May 2004
    Hey guys, thanks for the info. Never thought of that. Always thought my bass was a little lacking. I have to give that a try as well. (a piece of marble would look nice).
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
    edited May 2004
    I thought marble as well my wife will say no more money on the damn stereo...... so I used some MDF i had lying around
Welcome!
Welcome!
