How To Clean A Flat Screen Monitor?
digitalvideo
digitalvideo Posts: 983
edited December 2012 in Electronics
What's the best solution amd method to clean a flat panel glass plasma screen? I have a Pioneer Elite Kuro PRO-151FD. I was told that you should never use any liquid or fluid on a plasma glass screen, just stick to using a dry silk cloth supplied with the tv.
I was in Best Buy and they had Monster ScreenClean that looked interesting, though some of the reviews at Monster's own website don't give it high marks. Any good high quality respectable brands to choose from?
http://www.monstercable.com/productdisplay.asp?pin=4186
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=soho&cs=ussoho1&sku=A0479387&ST=SO_Office%20Accessories&dgc=ST&cid=248711&lid=4318532&acd=s_pla_SO50
Post edited by digitalvideo on
  • Syndil
    Syndil Posts: 1,582
    I stick with the dry cloth supplied with the screen (not microfiber) for my glass screens. If there's something particularly nasty on it I might fog it up with my breath first, but no sprays or anything. Works so far so I see no need to risk anything else.
    Don't use a microfiber towel. If the towel does pick up any grit, it will hold on to it and drag it across the screen.
    The cloths in the Belkin kit look a little better.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I have always had the best luck with straight water (lightly) on a very soft cloth. Never used chemicals and my screens are always looking like new!!:idea:
  • Monster Jam
    Monster Jam Posts: 919
    NOT this
    Do you hear that buzzing noise? :confused:
  • dkg999
    dkg999 Posts: 5,647
    Dragon Spit and 220 grit sandpaper.
    DKG999
  • seabeerob213
    seabeerob213 Posts: 1,843
    dont punch the screen, you'll bust up your hand and the tv,
  • specd_out
    specd_out Posts: 504
    I use the package kits for cleaning tvs. I run the tv for a few moments just to get the screen slighty warm, then I spray the towel lightly with the cleaner and clean the screen.
    Having the screen warm reduces and streaks, lightly misting the towel prevents the towel from scratching the glass.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • hdshatter
    hdshatter Posts: 14
    I've always used water on a softcloth except my pc monitor actually has some pretty hard to scratch glass over the flat panel, on that i used paper towels and windex.
    F1nut Posts: 52,299
    I use Windex and despite what they tell you, I haven't had any issues at all. That other "safe" cleaner stuff couldn't clean its way out of a paper bag.
  • Syndil
    Syndil Posts: 1,582
    There's a good reason they say not to use Windex--it contains ammonia. If there is any sort of film or coating attached to the screen, the ammonia will eat it away. Even if there is no coating on the outside of the glass, if the ammonia manages to seep into the bottom of the TV, it can wick its way up the other side of the screen and attack the coating on the reverse, and then you get something like this:
    Some Panasonic plasma TVs (and possibly others) have an anti-reflective coating on the outside of the glass. Spray it with Windex and it will look like this:
    At which point you may as well keep spraying/polishing in order to completely remove the now-ruined anti-reflective coating and expose the bare glass.
    That's why it is not wise to use Windex or any cleaner containing ammonia on a TV (or tinted windows, or any glass with a coating on it). So unless you're absolutely certain there is no coating on either side of your screen, it is a Very Bad Idea to use it! How dirty is your TV anyway??
    F1nut Posts: 52,299
    Like I said, been using Windex with no problems on a Panasonic plasma, 2 Samsung LCD's and an LCD computer monitor. YMMV.
    pitdogg2 Posts: 27,770
    I use a very soft cloth baby diaper mist it with distilled water and wipe. I bought a pack way back when CD first appeared work very good for both. I found my Panasonic Plasma rarely if ever get dirty on the screen on the back a whole nother story I vacuum the vents often.
  • Geoff4rfc
    Geoff4rfc Posts: 3,040
    I use "CleanScreen" solution and the cloth it comes with. Got it through WireLogic
  • michael1947
    michael1947 Posts: 775
    I have been using an anti-static plexiglass cleaner which usually get it done while using an old t shirt. I have just last week been working on my shop Samsung 40 lcd and I cannot seem to get the smear from the screen as it seems to just move it around. I use a gas space heater in the shop and combined with other shop "stuff" the screen gets slimy. I may try some windex.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • michael1947
    Just googled CleanScreen and didn't find the product but ran upon an interesting article at "ASK".com, and they recommend distilled water and white vinegar, 50/50 ratio. I'll give that a try.
  • Geoff4rfc
    Here you go, try this http://www.wirelogic.us/products.html
  • Geoff4rfc
    CleanScreen contents are; Deionized water and proprietary polomers.
  • monepolk
    monepolk Posts: 1,154
    Is that the code name for vinegar?:confused:
  • Tbone289
    Tbone289 Posts: 661
    I always use a screen/lens cloth lightly dampened with distilled water. If that isn't sufficient, I lightly dampen the cloth with distilled water and a little white vinegar. It has always worked perfectly for me, and I don't have to buy specialty cleaners.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    Best way to clean your screen.....buy a new one, they come out of the box nice and shiney.:cheesygrin:
  • Geoff4rfc
    tonyb wrote: »
    Best suggestion I've heard yet, see ya, I'm off to the store
  • acmf74
    acmf74 Posts: 937
    I've been using Phillps solution and microfiber for years.
    Works really well and no issues.
    http://www.shopko.com/detail/philips-green-lcdplasma-screen-cleaner/22849?gclid=CJnllrPTurQCFQyk4AodLAUAsw
  • seabeerob213
    i like breath fogging it and a lens cloth
  • Willow
    Willow Posts: 11,339
    Swiffer, nothing else gets on my tv but a bit of dust.
  • michael1947
    Thanks for the link to the clean screen.:eek:
  • astar13656
    astar13656 Posts: 164
    Dang, I guess I sould stop using Windex!
  • Geoff4rfc
    Your welcome. I found the score and took advantage of it.
    According to the link, you can get one 200ml (6.75oz) and one 12"x12" cloth for $20. Another selection is two 30ml (1oz) and one 6"x6" cloth for $16.
    I was in Costco last night and found among their selection of WireLogic HDMI packages, a CleanScreen kit. It contains two 200ml bottles, two 30ml bottles and two 12"x12" cloths. The price was $14.
    I believe I now own a lifetime supply of CleanScreen :mrgreen:
  • RamZet
    RamZet Posts: 792
    Micro fiber cloth is good. That monster spray is sketchy. Ixos made great spray but they just went out of business. : (
    B&W CM9Classé Sigma
  • cristo
    cristo Posts: 231
    I use Prima Clarity with a microfiber cloth (bought for car windshield,
    but use it on other windows, glass, mirrors, tv, monitor screens, etc.).
    "A powerful glass and plastic cleaner which cuts through grime, smoke and
    off-gassing, leaving a brilliant, streak-free finish. Clarity is without alcohol
    or ammonia making it safe for all glass and plastic surfaces, including tinted
    windows."
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • Syndil
    Syndil Posts: 1,582
    Keep in mind that not all microfiber is the same. A flat microfiber cloth is OK, but not a tufted microfiber towel. Towels are great if you need to scrub or polish something, as all of those tufts give you more surface area per wipe and are great at holding on to dirt. But you don't want to scrub or polish a coating, and you don't want to grind any dirt those tufts are holding on to into your screen's coating.
    A basic rule I go by is that if it feels at all grabby as you're wiping, don't use it. The cloth should glide as smoothly as possible over the surface. The tradeoff of course is that it may take more passes to clean since it's not scrubbing as effectively as a grabbier material, but what's more important, saving a few minutes wiping down your screen, or not damaging your screen?
    Being a holdout from the era of CRTs (all of my PC monitors are still CRTs) and having learned firsthand the fragility of screen coatings, I do perhaps tend to be a bit more anal than most about how I clean my screens. A ruined coating = a ruined screen as far as I am concerned. If someone were to approach any of my screens with Windex--or any chemical cleaner, or a paper towel, or any sort of tufted towel, or anything made out of paper (tissues, toilet paper, etc.), or anything other than water and a smooth, lint-free cloth--I'd probably be arrested for murder. Decent CRTs in decent condition are rare and therefore very difficult to replace, so I treat them like I'm a curator at a CRT museum, and that habit has carried on to my other screens as well. I know if it's safe for a coated CRT, it's safe for any screen. But obviously others may have different approaches.
    I would also like to say that while people will gladly sell you a screen-cleaning kit, don't think that you need to buy a screen-cleaning kit to clean your screen. Companies are all the time bundling stuff together and calling it some sort of kit and selling it at an insane markup, but rarely are they a good buy. It's great for marketing; not great for the consumer. A kit will usually have a bunch of stuff in it you will never need (in this case, the cleaning solution--just use water) and the stuff you do need (the cloth) will either be of questionable quality, or you will be able to buy separately for a lot less money.
    Personally I never like to use the same cloth to clean a screen more than once, so spending $20 for a few ounces of unnecessary fluid and one 12" x 12" cloth is not a good buy, IMO. You can buy multi-packs of large microfiber cloths for a lot less than $20 on Amazon.
  • thsmith
    thsmith Posts: 6,082
    What Panny says for my plasma
    Care and Cleaning
    First, unplug the Power cord plug from the wall outlet.
    Display panel
    The front of the display panel has been specially treated. Wipe the panel surface gently using only a cleaning cloth or a soft, lintf
    ●re e cloth. If the surface is particularly dirty, soak a soft, lint-free cloth in diluted mild liquid dish soap (1 part mild liquid dish soap diluted
    by 100 times the amount of water) and then wring the cloth to remove excess liquid. Use this cloth to wipe the surface of the
    display panel, then wipe it evenly with a dry cloth of the same type until the surface is dry. ● Do not scratch or hit the surface of the panel with fingernails or other hard objects. Furthermore, avoid contact with volatile
    substances such as insect sprays, solvents, and thinner; otherwise, the quality of the surface may be adversely affected.
    Cabinet
    If the cabinet becomes dirty, wipe it with a soft, dry cloth. ● If the cabinet is particularly dirty, soak the cloth in a weak mild liquid dish soap and then wring the cloth dry.
    Use this cloth to wipe the cabinet and then wipe it dry with a dry cloth. ● Do not allow any mild liquid dish soap to come into direct contact with the surface of the Plasma TV.
    If water droplets get inside the unit, operating problems may result. ● Avoid contact with volatile substances such as insect sprays, solvents, and thinner; otherwise, the quality of the cabinet surface
    may be adversely affected or the coating may peel off. ● Do not let articles made from rubber or PVC be in contact with the TV for long periods of time.
    Pedestal
    ● Cleaning
    Wipe the surfaces with a soft, dry cloth. If the unit is particularly dirty, clean it using a cloth soaked with water to which a small
    amount of mild liquid dish soap has been added and then wipe with a dry cloth.
    Do not use products such as solvents, thinner, or household wax for cleaning, as they can damage the surface coating. (If
    using a chemically-treated cloth, follow the instructions supplied with the cloth.) ● Do not attach sticky tape or labels, as they can make the surface of the pedestal dirty.
