Please help to hookup psw110.
link05
Please help,
My reciever has a single LFE sub output, but the PSW sub, just brought, does not has a singly LFE input. It has L & R LFE input. How do I hookup from single output from receiver to L & R LFE input.
JG
JG
Post edited by link05 on
Yes it does. I'm looking at mine right now. Just run your cable from the sub out jack on the AVR to the R/LFE jack on the sub.My humble setup...
...is no more.
Thanks for your help, I have the other question about power cord. The plug in power cord, how can I tell which is + or - terminal? it can be plugin left or right side? The 2 round same of +/- terminals are exact the same so how can I tell which side to plugin in?
JG -
The female end can be plugged into the sub either way.My humble setup...
...is no more.
goofy is right but the female end is the sub, the cord is the male end,2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
The male plugin can insert into female or the other way, both of them work. I got my sub humming. Thank you both
reported
