Please help to hookup psw110.
link05
link05 Posts: 3
Please help,
My reciever has a single LFE sub output, but the PSW sub, just brought, does not has a singly LFE input. It has L & R LFE input. How do I hookup from single output from receiver to L & R LFE input.
JG
Post edited by link05 on
  • goofyGAguy
    goofyGAguy Posts: 545
    edited November 2012
    link05 wrote: »
    Yes it does. I'm looking at mine right now. Just run your cable from the sub out jack on the AVR to the R/LFE jack on the sub.
    My humble setup...
    ...is no more. :cry:
  • link05
    link05 Posts: 3
    Thanks for your help, I have the other question about power cord. The plug in power cord, how can I tell which is + or - terminal? it can be plugin left or right side? The 2 round same of +/- terminals are exact the same so how can I tell which side to plugin in?
    JG
  • goofyGAguy
    link05 wrote: »
    The female end can be plugged into the sub either way.
    My humble setup...
  • seabeerob213
    seabeerob213 Posts: 1,843
    goofy is right but the female end is the sub, the cord is the male end,
  • link05
    link05 Posts: 3
    The male plugin can insert into female or the other way, both of them work. I got my sub humming. Thank you both
  • Syndil
    Syndil Posts: 1,582
    edited December 2012
    reported
