New Total Recall playback issues
bansheesho
bansheesho Posts: 227
edited January 2013 in Music & Movies
I was about to rip my receiver out and throw it against the wall until I realized that it is the encoding on the disk that was causing it. Seems that there is something wrong with the HD track that causes nasty audio cut outs and makes it pretty much unwatchable. I tried updating bdp firmware, spacing everything out with wood blocks, putting a fan on everything, wiggling cables. Finally I tried a different bluray and everything is working fine.
If you change to a non-HD format the movie is watchable again.
Just FYI for everyone
Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
Post edited by bansheesho on
  • bansheesho
    edited December 2012
    Switching the bdp to pcm mode also works. Highly annoying though.
    @@@@@ Posts: 114
    I watched it last night too and it caused me to give up watching it because of audio dropouts. It took place when he was playing the piano...
  • zane77
    zane77 Posts: 1,696
    Watched it Friday night with the same issues. Too bad Sony can't even get this to play properly on a Sony player.
    Two Channel
  • bansheesho
    Maybe Sony will issue a ...... Total Recall?
  • Strong Bad
    Strong Bad Posts: 4,278
    bansheesho wrote: »
    HAHA! Touche'
    No excuses!
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    There was issues with copies of Sony's Girl with dragon tattoo wouldn't play on some sony Br players.
  • 55LS70
    55LS70 Posts: 184
    It wouldn't even start up on my Pioneer blu-ray player. I finially gave up and watched the DVD copy. It played fine.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • jon s
    jon s Posts: 905
    Well, I had no dropouts, but the audio was delayed by about a second.... it was like watching an old Chinese Kung Fu movie...
  • B Run
    B Run Posts: 1,888
    Man I almost bought it on Bluray, glad I streamed it from Vudu it looked/sounded fantastic.
  • gdb
    gdb Posts: 6,012
    Huh, I guess it's good that BR was all out at Redbox and I got a regular DVD! Who's hottest, Jessica or Kate ????
  • zane77
    zane77 Posts: 1,696
    Kate all the way
    Two Channel
  • jim 249
    jim 249 Posts: 347
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Had same issue with Redbox BR. Audio delay horrible, no drop outs. Maxed my Onkyo's A/V sync to 250ms and still way off. First time I've had this type of error with playback.
  • Montoya
    Montoya Posts: 506
    I had issues with this disk also I used PCM and that fixed the problem however the sound seemed very muffled/veiled but it let me see the movie.:neutral:
  • jeremymarcinko
    Yeahp me too. Not until an hour into it though.
  • brittle
    brittle Posts: 37
    edited January 2013
    i didn't find this movie watchable in any format, ha ha
    Brittle
    Pioneer VSX 94TXH AVR
    Polk LSi-15 front
    Polk LSi-15 rear
    Polk PSW1000 sub
    Polk LSiC center
    Samsung HL67A750 DLP
    Sony PS3
