New Total Recall playback issues
bansheesho
I was about to rip my receiver out and throw it against the wall until I realized that it is the encoding on the disk that was causing it. Seems that there is something wrong with the HD track that causes nasty audio cut outs and makes it pretty much unwatchable. I tried updating bdp firmware, spacing everything out with wood blocks, putting a fan on everything, wiggling cables. Finally I tried a different bluray and everything is working fine.
If you change to a non-HD format the movie is watchable again.
Just FYI for everyone
Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
Post edited by bansheesho on
Switching the bdp to pcm mode also works. Highly annoying though.Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
I watched it last night too and it caused me to give up watching it because of audio dropouts. It took place when he was playing the piano...
Watched it Friday night with the same issues. Too bad Sony can't even get this to play properly on a Sony player.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Maybe Sony will issue a ...... Total Recall?Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
bansheesho wrote: »Maybe Sony will issue a ...... Total Recall?
HAHA! Touche'No excuses! -
There was issues with copies of Sony's Girl with dragon tattoo wouldn't play on some sony Br players.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
It wouldn't even start up on my Pioneer blu-ray player. I finially gave up and watched the DVD copy. It played fine.Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
Cambridge Audio 640C V2 CD Player & Dacmagic DAC
Rega Planar 3: Deep Groove Subplatter, P3 Motor
upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor. -
Well, I had no dropouts, but the audio was delayed by about a second.... it was like watching an old Chinese Kung Fu movie...
Man I almost bought it on Bluray, glad I streamed it from Vudu it looked/sounded fantastic.
Huh, I guess it's good that BR was all out at Redbox and I got a regular DVD! Who's hottest, Jessica or Kate ????
Kate all the wayHome Theater
Two Channel
Bump
Had same issue with Redbox BR. Audio delay horrible, no drop outs. Maxed my Onkyo's A/V sync to 250ms and still way off. First time I've had this type of error with playback.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
I had issues with this disk also I used PCM and that fixed the problem however the sound seemed very muffled/veiled but it let me see the movie.
Yeahp me too. Not until an hour into it though.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
i didn't find this movie watchable in any format, ha haBrittle
Pioneer VSX 94TXH AVR
Polk LSi-15 front
Polk LSi-15 rear
Polk PSW1000 sub
Polk LSiC center
Samsung HL67A750 DLP
Sony PS3
