Lexicon CP-1 (plus) remote help?
ambiophonics
Hey Guys,
Thought i'd start a new thread for this. Another member started a thread about the Lexicon CP-1 which prompted me to pull mine out of storage. I'd like to hook it up and see how it sounds but I don't have the remote anymore. I tried to add it as a device to my harmony 550 remote control but most of the codes are incomplete and do not allow me to even set the unit up or adjust the volume. Does anyone know how to get the proper codes added to my harmony? I found the hex codes online but logitech wants 30 bucks to add them to the database (you'd think they would want to expand their code list). Does anyone have a remote they could learn commands from and somehow add to my account? Any ideas?
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Post edited by ambiophonics on
Thats a tough one. To my knowledge without the original remote i thinl its a boat anchor. Ck fleebay u might come up with one. I have seen some recently ( at least lexicon remotes, not sure which models).Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Just checked there is one under "lecicon remotes" for 44.00 free ship. (no afil.) it is identical to me cp1 remote.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Thanks soundfreak, i'll check that one out. I just wish logitech/harmony had the codes for it so I could do this the easy way!2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
No help on the remote, but I have a CP-1 and it sounds great. I'm just using it as a DAC/Pre in a small 2-channel music setup. Good luck finding your remote.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Well I have found a way to convert some remote HEX codes and got my harmony setup to run the unit. I'm a bit confused though, I did a factory reset on the unit but the "presets" which are labeled 1-12 on the remote, don't seem to match up with what the manual says, and the preset I wanted to try, panorama, is not one of them! I have presets such as, "practice room", recital hall small, medium, large, cathedral, arena, etc... what kind of presets do you guys have on your CP-1's? I thought panorama was supposed to be preset #1?2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
