Sorry - no matches. Please try some different terms.
Dukes of Daisy
Dukes of Daisy Posts: 1
edited December 2012 in Forum Testing Area
before I became a member, this was typically the return I get using the search tool.
*example* I search:
DSW PRO 660wi
ok, I'll lighten the load.
dsw 660
:neutral:
660
what's the trick?
Post edited by Dukes of Daisy on
  • teekay0007
    teekay0007 Posts: 2,288
    First off, Welcome to Club Polk!! I hope you find this site inviting, friendly and informative and that you decide to stick around for a while.
    The search tool here doesn't do much for me either. What I found to work pretty well is to use google and make a search entry something like this (specific to your search topic):
    DSWPRO 660wi site:polkaudio.com/forums
    If you want all entries on this site (ie. including the item's product pages, etc. and not just forum threads/posts) for the item listed, you would do your search without the /forums part:
    You also might want to try different ways of listing the threads you're after since I'm not sure if it will ignore spacing issues. For example:
    DSW PRO 660 wi, DSWPRO660wi, etc.
    Additionally, if you're interested in info on this specific sub, you might also want to search for information on the DSWPRO600 since it's the EXACT SAME sub except for the discontinued 600 wasn't "wireless ready" like the 660wi model is, but all the other info would apply.
    Hope this helps you find what you're looking for. Good luck.
  • BlueFox
    BlueFox Posts: 15,250
    *example* I search:
    DSW PRO 660wi
    dsw 660
    :neutral:
    660
    what's the trick?
    Advanced search. Search in posts for dsw600
    http://www.polkaudio.com/forums/search.php?searchid=1517210
  • mdaudioguy
    mdaudioguy Posts: 5,164
    I believe search terms must be at least 4 characters.
