Sorry - no matches. Please try some different terms.
Dukes of Daisy
before I became a member, this was typically the return I get using the search tool.
*example* I search:
DSW PRO 660wi
ok, I'll lighten the load.
dsw 660
660
what's the trick?
*example* I search:
DSW PRO 660wi
dsw 660
660
what's the trick?
Post edited by Dukes of Daisy on
First off, Welcome to Club Polk!! I hope you find this site inviting, friendly and informative and that you decide to stick around for a while.
The search tool here doesn't do much for me either. What I found to work pretty well is to use google and make a search entry something like this (specific to your search topic):
DSWPRO 660wi site:polkaudio.com/forums
If you want all entries on this site (ie. including the item's product pages, etc. and not just forum threads/posts) for the item listed, you would do your search without the /forums part:
You also might want to try different ways of listing the threads you're after since I'm not sure if it will ignore spacing issues. For example:
DSW PRO 660 wi, DSWPRO660wi, etc.
Additionally, if you're interested in info on this specific sub, you might also want to search for information on the DSWPRO600 since it's the EXACT SAME sub except for the discontinued 600 wasn't "wireless ready" like the 660wi model is, but all the other info would apply.
Hope this helps you find what you're looking for. Good luck. -
Dukes of Daisy wrote: »before I became a member, this was typically the return I get using the search tool.
*example* I search:
DSW PRO 660wi
dsw 660
660
what's the trick?
Advanced search. Search in posts for dsw600
http://www.polkaudio.com/forums/search.php?searchid=1517210Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I believe search terms must be at least 4 characters.
