is svs 25-31 + good with rti12?
umjs78
i'm not sure which modeel of svs fit to my situation
i have rti12 then should i get 25-31?
let me know lz...
let me know lz...
Post edited by umjs78 on
If you have decided you want to go with an SVS email them with the info about your room dimensions, budget and expectations and they will quickly recommend the best options.Graham
Definately e-mail SVS. With the RTi12's already provided bass quite nicely on the higher regions I would think the 16Hz or 20Hz models would suit better, providing more bass down low. SVS guys will tell you more. You can also find a lot of SVS discussion at http://www.hometheaterforum.com/index.php
- What are the room dimensions and ceiling height.
- Where will the sub be placed in the room.
- How far are the key listening positions from the sub.
- How many permanent openings are in the room, and where will the sub be located in relation to them.
- What type of DVDs and music to you like and what is the listening percentage for each.
- When calibrating for HT applications, how "hot" do you run your sub, compared to your speaker channels?
- What is your typical master volume setting with respect to Reference Level (like -5RL, -10RL, -15RL) when watching DVDs.
- Which form factor do you prefer more: Box or Cylinder.
- Which finish option do you prefer: Black or Wood.
- What is your budget?"What we do in life echoes in eternity"
SVS
