looking for recommendations for a good subwoofer for my Dahlquist DQ 10 speakers
pglbook
I am looking to get a good subwoofer for my Dahlquist DQ 10 speakers because, while the DQ 10s do have great imaging and an incredibly clear sound, they do lack some bass.
Can anyone recommend a good subwoofer?
I know nothing about subwoofers.
My budget is around $300 which, I know, is not a lot for a good subwoofer but I am looking for either new or used so hopefullly there is a decent subwoofer in my price range.
Thanks.
Thanks.
Post edited by pglbook on
You can pick up a nice Polk Micro Pro or REL for that money. I have both and great for filling in the low end for LSI9's.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Thanks for the recommendation. I will definitely look into those sybwoofers. I appreciate it.
Hello, pglbook. Just out of curiosity and nothing else, is this budget set after the X-over upgrades? While I do agree with you about them being a tad light on the bass...
I am using a HSU STF-2 subwoofer with my DQ-10's.
I bought it for $200 new on a closeout at Circuit City. Very musical, not boomy and integrates well with the DQ-10's and DQ-20's.
Currently looking for a used HSU STF-3 as an upgrade.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
Thanks, treitz3. The crossover upgrades are my first priority and the subwoofer is more of a long term wish I guess. I definitely want to go ahead with the crossover upgrade. My budget (like everyone's) is limited so I would not be able to do everything I'd like to do to the DQ 10s (new crossovers, subwoofer, etc) and there also comes a maximum dollar limit as to what one would want to spend on 30+ year old speakers, even DQ 10s. The DQ 10s only cost me $250 and its ok for me to put a few hundred more into them but at some point there is breaking point, where one wonders whether to spend a lot of money upgrading older speakers or spending that money on other (more expensive) speakers that may not require as much of an upgrade, etc. That is the eternal debate and I know there is no easy or correct answer there. It is a matter of preference, taste, and, of course budget. I definitely would like to do the crossovers on the DQ 10s, though. I think that will help them a lot. I got the DQ 10s a few months ago because I have heard so much about them and, to be honest, I was disappointed with them. Yes, they do have great clarity and imaging, as everyone says, but I found them rather flat and lifeless. Not very lively at all. And definitely lacking some bass. I am hoping the crossovers will improve them and bring them to life. Thanks for the response.
Dahlquist made a sub for the DQ-10 speakers back in the day. If you could find one, it would be a nice match, and probably within your budget. I also agree that once you upgrade the crossovers, the speakers should sound much better. $250 was a steal for those.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
I had DQ10s and used 2 Dahlquist "low bass modules". The LBMs were ho-hum in performance.
I recommend Velodyne or Hsu. -
I know where there was one of these a month or so back, it was at POP's resale in LExington, KY. HE sold the DQ10's he had but not the matching bass module.
I also have the original DQ passive subwoofer and crossover but prefer the HSU.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
The title sums it up pretty well. I'm looking at making some custom cables, mostly RCA, for my rig and would like some input on where you guys buy your bulk cable, connectors, etc. Any input is appreciated. Thanks
where can you get a micro pro for that money? thnking of upgrading from my PSW110 but didnt think i could afford something like that, and the normal dsw wasnt enough of an upgrade for my2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA
