Polk 5Jr for music
Jimbo18
I tried to buy a local pair of Monitor 4s I was going to use as surrounds, but the seller decided to pull them off sale and I have now found a pair of Monitor 5JRs for $75. I haven't seen them in person yet, and the pictures don't show much other than the model and the front covers but they appear to be cosmetically okay.
Would they pair okay with a Pioneer VSX 821K for music in a fairly large bedroom? They would also be used for television, possibly with a small center channel like the CS175. Just from the look of them, they seem like they might be similar to the Monitor 7s. Right now I am just using RT35i with the Pioneer AVR and, based on the Monitor 7's, I think I would like the 5JRs better for music.
Post edited by Jimbo18 on
They'll work fine.
Not a great price though.
I use 5jr+'s for my broom sys, and they sound fantastic.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
They'll work fine.
I figured it might be a little high and they have been listed before, so he might come down a bit. -
Do you know which version of 5Jr they be?
Monitor 5Jr (1984-1985)
Bass reflex (ported) design.
Midrange 1 - 6-1/2" Diameter (16.51cm) drivers
MW6502
Tweeter 1 - 1" Diameter (2.54cm)
Polk SL2000 silver coil dome tweeter
Overall Frequency Response 30Hz - 26kHz
Crossover Frequency 3000Hz
Nominal Impedance 4 ohms
Recommended Amplifier Power 10-100 w/channel
Efficiency 92 dB
Max Output Level 114 dB
Dimensions Cabinet Size 17" H x 9" W x 8.875" D
Weight 45. lbs./ pair
Monitor 5Jr+ (1986-1990)
Passive Radiator design
Had a 6.5" PR
SL-2000 tweeter
6.5" MW
Overall Frequency Response 30Hz - 26kHz (+/-3dB: 48Hz ? 20KHz)
Nominal Impedance 6 ohms
Recommended Amplifier Power 20-125 w/channel
Efficiency 91 dB
Monitor 5Jr+ Series 2 (1990)
PR - 6-1/2" Diameter (16.51cm)
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Polk SL2500 dome tweeter
Overall Frequency Response 30Hz - 25kHz
Lower -3dB Limit 48Hz
Upper -3dB Limit 23kHz
Nominal Impedance 8 ohms
Efficiency 90 dB
Dimensions Cabinet Size 19-1/2" H x 9" W x 10" D
(49.53cm H x 22.86cm W x 25.40cm D)
Notice that the first version was rated 4 ohm.Stan
Main 2ch:
HT:
Other stuff:
WHich of the 3 is considered the best?
I agree $75 is on the high side but if in great shape I doubt you will find a better sounding new speaker for $75.Speakers: SDA-1C (most all the goodies)
Efficiency 90 dB
I have these and like them a lot, they were my first pair of Polks purchased new. I think you'll be fine for bedroom speakers whichever version they happen to be.Monitor 7C's With Tubes -
Don't know if you're ever in Wilmington, but.... this seller seems to be a good guy (according to two buyers) and usually has interesting used gear at reasonable prices from what I can tell. Here are his Jr's:
http://wilmington.craigslist.org/ele/3484050264.html
CraigBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
75 isn't terrible for those. But as far as music, I thought most people here were of the Monitor 7s as the best of the Monitors for that?
Not that juniors wouldn't be good. I suspect they might sound a little "thin" with that Pioneer receiver. I run my 5As off an old JVC receiver that just sounds perfect for them, even though on paper, it's less powerful than your 821K Pio. The JVC can legitimately drive a 4 ohm load which the Pioneer cannot!
Enjoy!
After I started this thread, I saw that one of the various versions was 4 ohms and that does concern me with just the Pio to drive them. Here's the ad, which really doesn't give me much of a clue as to the version but I have asked for more pictures before we go any further with a sale. The label shows 5JR without a +. Does that mean they must be the 4 ohm version?
http://charlotte.craigslist.org/ele/3482024617.html
I told the seller that I am only looking for the 8 ohm version. If I get the photos I requested, I will post them. There is a set of Monitor 7s for sale for the same price with another seller, and if this doesn't work out, I may go that way. The tweets won't match my 7c's with SL2500's but I didn't intend to use them together. -
I heard a pair of the +'s and they sounded great for the size! 75 (if in great shape) will be hard to beat!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Jim,I'm going to be the voice in your head. (Get the 7s)
Dan -
Oldfatdogs wrote: »Jim,I'm going to be the voice in your head. (Get the 7s)
Dan
Yep, get the 7's.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
[video=youtube_share;sD8vwxhxKpA]
http://youtu.be/sD8vwxhxKpA[/video] "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
lucky 7's
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I am sensing a theme here. Sounds like the 7's are the way to go. Thanks for the advice.
Here's the photos that I was sent for the 5JRs. They look like they are in nice shape. They do not have the ported design but do have the silver dome tweeter and the PR. Does that make them 5JR+ and therefore 6 ohms?
You got it. The original 5jr+ with SL2000 tweeters.Jay
Unless space constraints are the key issue, then go with the 7's for the same $ or we will make fun of you when you decide to find a pair of 7's in a couple of months
2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
If you really want a pair of 7's, I have some with Peerless and Larry's rings that I would install and dynamat the drivers and passive for you for $150. I may be coming to the Charlotte area in a couple weeks or I have family that lives there in for Christmas right now that could deliver to you when they go back Thursday, but you'd have to install the rings yourself for $125.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
I turned down the 5JRs cuz I don't like being laughed at.
But I let the seller know exactly what they are and suggested they add the new pics to the CL ad.
TNHNDYMAN, let me think about it over the holidays. We are heading to Miss. for Christmas and will be gone most of next week. I have a job interview next week and those 7s would be a nice present to myself if all goes well. I haven't heard Peerless tweets yet and would love to hear them versus the SL2500s in my 7Cs. -
Good choice on the 7s! You will be happy. TNHNDYMAN's mods sound interesting - I've never heard of a rings upgrade for the monitor series. And how to you apply the dynamat?
I have a pair of Polk Mon 7As that sooner or later I would like to do a full resto on - caps, re-veneer the cabinets, etc. Who knows if I'll ever get around to it though!!
BYW - I have a 5jr+ that I'm currently using as a center channel in my all Polk Monitor HT setup (thanks TNHNDYMAN!). Sounds great. When I demoed it against my monitor 7s, the voicing is right there, but there is less bass. For a bedroom or TV setup I personally think you wouldn't be missing much vs the 7s that you wouldn't be gaining in size and packaging efficiency, especially if you really never crank the tunes in that room. That said, I had a pair of the Monitor 4s and was not as impressed....HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100 -
gmjungbluth wrote: »Good choice on the 7s! You will be happy. TNHNDYMAN's mods sound interesting - I've never heard of a rings upgrade for the monitor series. And how to you apply the dynamat?
I had actually considered getting the 5JRs and using one for the center in my HT setup, but I feel like the speaker would be a bit large for that the way I am set up, and the ones for sale currently, won't timbre match with my 7Cs. If I go that route, I would either have to find ones with the SL2500 tweeters or head down that rabbit hole and upgrade them all, which is something I just can't do currently.
My other thought was to pick up the 5JRs to use as rear surrounds with my 7Cs. The timbre matching wouldn't matter much, if at all, as surrounds. My family room isn't currently set up well to use anything larger than the 5JRs as surrounds. -
The 5Jr's would make nice surrounds I would think for a nice vintage HT setup. As to the 7's Jimbo just let me know. I have not installed the rings on the 7's yet but do have them available. There are several threads that speak to how to install them as well as the dynamat and JB welding the magnets on the midwoofers to keep the magnets from shifting during transport. I'm in the Tri Cities region of TN so I'm about 3 hrs from Charlotte. Feel free to PM for contact info and I'd be happy to discuss with you. Enjoy your Christmas break and there is no rush, just wanted to throw you an option out there. I really don't want to get rid of the 7's but some medical bills and other needs have changed some priorities for me for the time being.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
PM sent. -
You haven't been around long enough to see what these sleepless bastages dream up regarding "mods" to old Polks. Rings, Black hole 5, Cardas binding posts, JB weld, primo crossover upgrades, dynamat (just pull your drivers out and afix it to all the metal surface supports and maybe add some to your goatee so those hairs don't resonate when listening). Soon you'll be waking up at 3 AM and wondering "what else can I do to my Polk speakers". Then calling a fellow Polkie and having him scream: "Go to SLEEP, for God's sake! What the Fs the matter with you?"
LOL - great reply!
I'll put the dynamat driver and facial coating on the list for my 7s when I get around to them. I have done the JB Weld mod, after having to replace two drivers after they seized.
Funny, but I spend more time tinkering with speakers and stereos than I do listening to them. But I'm ok with that!
And so far no 3AM wake-ups thinking about the Polks - stays all in my dreams!You haven't been around long enough to see what these sleepless bastages dream up regarding "mods" to old Polks. Rings, Black hole 5, Cardas binding posts, JB weld, primo crossover upgrades, dynamat (just pull your drivers out and afix it to all the metal surface supports and maybe add some to your goatee so those hairs don't resonate when listening). Soon you'll be waking up at 3 AM and wondering "what else can I do to my Polk speakers". Then calling a fellow Polkie and having him scream: "Go to SLEEP, for God's sake! What the Fs the matter with you?"
cnhHT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100 -
I sent a second PM but nothing shows in my Sent file. Did you get my message? -
Sorry Jimbo- I got it. Been busy today and thought I had some company coming in tomorrow so I was trying to clean and pick up the house a bit. Send me some contact info and we can talk to discuss details. I've got family living in Charlotte so I don't need much of an excuse to come down that way.. lol2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
cnh
This is what happens when you take 5 hour energy drinks at bed time.
Of course it did not help that someone mentioned to their fellow polkie member during that 3AM conversation - "Watson - I need you now!!!"Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart.
