Polk 5Jr for music
Jimbo18
Jimbo18 Posts: 2,351
edited January 2013 in Vintage Speakers
I tried to buy a local pair of Monitor 4s I was going to use as surrounds, but the seller decided to pull them off sale and I have now found a pair of Monitor 5JRs for $75. I haven't seen them in person yet, and the pictures don't show much other than the model and the front covers but they appear to be cosmetically okay.
Would they pair okay with a Pioneer VSX 821K for music in a fairly large bedroom? They would also be used for television, possibly with a small center channel like the CS175. Just from the look of them, they seem like they might be similar to the Monitor 7s. Right now I am just using RT35i with the Pioneer AVR and, based on the Monitor 7's, I think I would like the 5JRs better for music.
Post edited by Jimbo18 on
  • Mystery
    Mystery Posts: 2,546
    edited December 2012
    They'll work fine.
    Not a great price though.
  • soundfreak1
    soundfreak1 Posts: 3,414
    I use 5jr+'s for my broom sys, and they sound fantastic.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Jimbo18
    Mystery wrote: »
    They'll work fine.
    I figured it might be a little high and they have been listed before, so he might come down a bit.
  • skrol
    skrol Posts: 3,464
    Do you know which version of 5Jr they be?
    Monitor 5Jr (1984-1985)
    Bass reflex (ported) design.
    Midrange 1 - 6-1/2" Diameter (16.51cm) drivers
    MW6502
    Tweeter 1 - 1" Diameter (2.54cm)
    Polk SL2000 silver coil dome tweeter
    Overall Frequency Response 30Hz - 26kHz
    Crossover Frequency 3000Hz
    Nominal Impedance 4 ohms
    Recommended Amplifier Power 10-100 w/channel
    Efficiency 92 dB
    Max Output Level 114 dB
    Dimensions Cabinet Size 17" H x 9" W x 8.875" D
    Weight 45. lbs./ pair
    Monitor 5Jr+ (1986-1990)
    Passive Radiator design
    Had a 6.5" PR
    SL-2000 tweeter
    6.5" MW
    Overall Frequency Response 30Hz - 26kHz (+/-3dB: 48Hz ? 20KHz)
    Nominal Impedance 6 ohms
    Recommended Amplifier Power 20-125 w/channel
    Efficiency 91 dB
    Monitor 5Jr+ Series 2 (1990)
    PR - 6-1/2" Diameter (16.51cm)
    Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
    Polk SL2500 dome tweeter
    Overall Frequency Response 30Hz - 25kHz
    Lower -3dB Limit 48Hz
    Upper -3dB Limit 23kHz
    Nominal Impedance 8 ohms
    Efficiency 90 dB
    Dimensions Cabinet Size 19-1/2" H x 9" W x 10" D
    (49.53cm H x 22.86cm W x 25.40cm D)
    Notice that the first version was rated 4 ohm.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • thsmith
    thsmith Posts: 6,082
    WHich of the 3 is considered the best?
    I agree $75 is on the high side but if in great shape I doubt you will find a better sounding new speaker for $75.
  • vstarkwell
    vstarkwell Posts: 328
    skrol wrote: »
    Efficiency 90 dB
    I have these and like them a lot, they were my first pair of Polks purchased new. I think you'll be fine for bedroom speakers whichever version they happen to be.
    Monitor 7C's With Tubes
  • vcwatkins
    vcwatkins Posts: 1,992
    Don't know if you're ever in Wilmington, but.... this seller seems to be a good guy (according to two buyers) and usually has interesting used gear at reasonable prices from what I can tell. Here are his Jr's:
    http://wilmington.craigslist.org/ele/3484050264.html
    Craig
    75 isn't terrible for those. But as far as music, I thought most people here were of the Monitor 7s as the best of the Monitors for that?
    Not that juniors wouldn't be good. I suspect they might sound a little "thin" with that Pioneer receiver. I run my 5As off an old JVC receiver that just sounds perfect for them, even though on paper, it's less powerful than your 821K Pio. The JVC can legitimately drive a 4 ohm load which the Pioneer cannot!
    Enjoy!
    cnh
  • Jimbo18
    After I started this thread, I saw that one of the various versions was 4 ohms and that does concern me with just the Pio to drive them. Here's the ad, which really doesn't give me much of a clue as to the version but I have asked for more pictures before we go any further with a sale. The label shows 5JR without a +. Does that mean they must be the 4 ohm version?
    http://charlotte.craigslist.org/ele/3482024617.html
    I told the seller that I am only looking for the 8 ohm version. If I get the photos I requested, I will post them. There is a set of Monitor 7s for sale for the same price with another seller, and if this doesn't work out, I may go that way. The tweets won't match my 7c's with SL2500's but I didn't intend to use them together.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I heard a pair of the +'s and they sounded great for the size! 75 (if in great shape) will be hard to beat!
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Jim,I'm going to be the voice in your head. (Get the 7s) :smile:
    Dan
  • vcwatkins
    Oldfatdogs wrote: »
    Dan
    Yep, get the 7's.
    EndersShadow Posts: 17,722
    [video=youtube_share;sD8vwxhxKpA]http://youtu.be/sD8vwxhxKpA[/video]
  • PolkieMan
    PolkieMan Posts: 2,446
    lucky 7's:mrgreen:
  • Jimbo18
    I am sensing a theme here. Sounds like the 7's are the way to go. Thanks for the advice.
  • Jimbo18
    Here's the photos that I was sent for the 5JRs. They look like they are in nice shape. They do not have the ported design but do have the silver dome tweeter and the PR. Does that make them 5JR+ and therefore 6 ohms?
  • agfrost
    agfrost Posts: 2,474
    You got it. The original 5jr+ with SL2000 tweeters.
    Jay
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Unless space constraints are the key issue, then go with the 7's for the same $ or we will make fun of you when you decide to find a pair of 7's in a couple of months ;)
  • TNHNDYMAN
    If you really want a pair of 7's, I have some with Peerless and Larry's rings that I would install and dynamat the drivers and passive for you for $150. I may be coming to the Charlotte area in a couple weeks or I have family that lives there in for Christmas right now that could deliver to you when they go back Thursday, but you'd have to install the rings yourself for $125.
  • Jimbo18
    I turned down the 5JRs cuz I don't like being laughed at. :wink: But I let the seller know exactly what they are and suggested they add the new pics to the CL ad.
    TNHNDYMAN, let me think about it over the holidays. We are heading to Miss. for Christmas and will be gone most of next week. I have a job interview next week and those 7s would be a nice present to myself if all goes well. I haven't heard Peerless tweets yet and would love to hear them versus the SL2500s in my 7Cs.
  • gmjungbluth
    gmjungbluth Posts: 232
    Good choice on the 7s! You will be happy. TNHNDYMAN's mods sound interesting - I've never heard of a rings upgrade for the monitor series. And how to you apply the dynamat?
    I have a pair of Polk Mon 7As that sooner or later I would like to do a full resto on - caps, re-veneer the cabinets, etc. Who knows if I'll ever get around to it though!!
    BYW - I have a 5jr+ that I'm currently using as a center channel in my all Polk Monitor HT setup (thanks TNHNDYMAN!). Sounds great. When I demoed it against my monitor 7s, the voicing is right there, but there is less bass. For a bedroom or TV setup I personally think you wouldn't be missing much vs the 7s that you wouldn't be gaining in size and packaging efficiency, especially if you really never crank the tunes in that room. That said, I had a pair of the Monitor 4s and was not as impressed....
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
  • Jimbo18
    I had actually considered getting the 5JRs and using one for the center in my HT setup, but I feel like the speaker would be a bit large for that the way I am set up, and the ones for sale currently, won't timbre match with my 7Cs. If I go that route, I would either have to find ones with the SL2500 tweeters or head down that rabbit hole and upgrade them all, which is something I just can't do currently.
    My other thought was to pick up the 5JRs to use as rear surrounds with my 7Cs. The timbre matching wouldn't matter much, if at all, as surrounds. My family room isn't currently set up well to use anything larger than the 5JRs as surrounds.
  • TNHNDYMAN
    The 5Jr's would make nice surrounds I would think for a nice vintage HT setup. As to the 7's Jimbo just let me know. I have not installed the rings on the 7's yet but do have them available. There are several threads that speak to how to install them as well as the dynamat and JB welding the magnets on the midwoofers to keep the magnets from shifting during transport. I'm in the Tri Cities region of TN so I'm about 3 hrs from Charlotte. Feel free to PM for contact info and I'd be happy to discuss with you. Enjoy your Christmas break and there is no rush, just wanted to throw you an option out there. I really don't want to get rid of the 7's but some medical bills and other needs have changed some priorities for me for the time being.
  • Jimbo18
    TNHNDYMAN wrote: »
    PM sent.
    You haven't been around long enough to see what these sleepless bastages dream up regarding "mods" to old Polks. Rings, Black hole 5, Cardas binding posts, JB weld, primo crossover upgrades, dynamat (just pull your drivers out and afix it to all the metal surface supports and maybe add some to your goatee so those hairs don't resonate when listening). Soon you'll be waking up at 3 AM and wondering "what else can I do to my Polk speakers". Then calling a fellow Polkie and having him scream: "Go to SLEEP, for God's sake! What the Fs the matter with you?"
    cnh
  • gmjungbluth
    LOL - great reply!
    I'll put the dynamat driver and facial coating on the list for my 7s when I get around to them. I have done the JB Weld mod, after having to replace two drivers after they seized.
    Funny, but I spend more time tinkering with speakers and stereos than I do listening to them. But I'm ok with that!
    And so far no 3AM wake-ups thinking about the Polks - stays all in my dreams!
    cnh wrote: »
    cnh
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    2Ch:
    Living Room:
    Harman Kardon 3380
    Bedroom:
    Polk PSW10
    KLH Model 6,
    Polk LSI7
    NAD 7100
  • Jimbo18
    edited January 2013
    TNHNDYMAN wrote: »
    I sent a second PM but nothing shows in my Sent file. Did you get my message?
  • TNHNDYMAN
    edited January 2013
    Sorry Jimbo- I got it. Been busy today and thought I had some company coming in tomorrow so I was trying to clean and pick up the house a bit. Send me some contact info and we can talk to discuss details. I've got family living in Charlotte so I don't need much of an excuse to come down that way.. lol
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited January 2013
    cnh wrote: »
    cnh
    This is what happens when you take 5 hour energy drinks at bed time.
    Of course it did not help that someone mentioned to their fellow polkie member during that 3AM conversation - "Watson - I need you now!!!"
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
