What kind of wires do the monitor series II speakers use???
dizzyrapper18
i have not opened my polk monitor60, cs1, monitor30 and a psw505 sub so im wondering if anyone can point me in the right direction on the type of wires they use.
ive asked for a denon 2113ci receiver for xmas so im hoping ill get it
Post edited by dizzyrapper18 on
That is a nice setup that you should be very pleased with. Any speaker wire will work, but if you're on a budget I would suggest this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2789&seq=1&format=2
and this: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=9436&seq=1&format=2
Make sure you measure to see how much cable you need. You will need a pair of wire clippers to splice the wire.
Also, monoprice is very cheap but does not offer free shipping. So while you at it get whatever HDMI cables or other cables that you need. It never hurts to have a few extra, ut it sucks to not be able to get everything hooked up because you are missing one cable.
good luck!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
the bananna plugs you suggested seem to go in the receiver side but in the movie says speakers need pin screw type.
does it matter if its pin screw or regular plug? -
Your speakers will accept banana plugs, spades or bare wire.Political Correctness'.........defined
President of Club Polk -
and would 14 gauge 16 or 18 be better? i dont want anything too big ya know.
These are a lot better banana plugs than the one's I've seen people posting:
http://www.knukonceptz.com/productDetail.cfm?prodID=eKs-BP2
They contact the terminals along their full length. "Normal" banana plugs only contact the terminal at their widest point. Perhaps about a third of their length."The ear is not a microphone, the brain is not a tape recorder, and measurements are limited in describing subjective quality." Nelson Pass
2 Channel:
XDA-2, Modified Jolida JD502P (2 ea), Polk LSiM705
Theater:
Onkyo TX-NR3009 with 9 active channels, Emotiva XPA-5, MartinLogan Encore TF Center Channel, Polk M70 Mains, M40 Wides, M30 Heights, FXi A4 Surrounds, Custom built 18" sub, Mitsu 73" DLP
