newbie question!
jaf09
What is dac, and lossles files nad how it works!!! Thanks for any help!!!!!
Post edited by jaf09 on
Here are a few links to get you started...
Look under "Applications" and "Audio" as it pertains to most of the discussions on CP:
http://en.wikipedia.org/wiki/Digital-to-analog_converter
For lossless audio read this:
http://en.wikipedia.org/wiki/Audio_file_format and http://mp3.about.com/od/glossary/g/Lossless-Definition-What-Is-A-Lossless-Audio-Format.htm➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Thank you,does this really makes that much improvement in audio quality!!
Yes. Try ''www.computeraudiophile.com'' and click on FAQ. Should help you out. Hit forum first then click FAQ
Thanks good info! -
I got a pioneer receiver an xpa3,if i were to get a dac how should i plug it and what would be the most beneficiary source.
I love music and truly appreciate a good clear sound! but i equally use my system for movies would all this work together!!
