newbie question!
jaf09
jaf09 Posts: 48
What is dac, and lossles files nad how it works!!! Thanks for any help!!!!!
  • JayCee
    JayCee Posts: 1,509
    edited December 2012
    jaf09 wrote: »
    Here are a few links to get you started...
    Look under "Applications" and "Audio" as it pertains to most of the discussions on CP:
    http://en.wikipedia.org/wiki/Digital-to-analog_converter
    For lossless audio read this:
    http://en.wikipedia.org/wiki/Audio_file_format and http://mp3.about.com/od/glossary/g/Lossless-Definition-What-Is-A-Lossless-Audio-Format.htm
    ➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S3.3 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • jaf09
    jaf09 Posts: 48
    Thank you,does this really makes that much improvement in audio quality!!
  • chumlie
    chumlie Posts: 8,658
    Yes. Try ''www.computeraudiophile.com'' and click on FAQ. Should help you out. Hit forum first then click FAQ
  • jaf09
    jaf09 Posts: 48
    chumlie wrote: »
    Thanks good info!
  • jaf09
    jaf09 Posts: 48
    I got a pioneer receiver an xpa3,if i were to get a dac how should i plug it and what would be the most beneficiary source.
    I love music and truly appreciate a good clear sound! but i equally use my system for movies would all this work together!!
