Banana Plugs
rodelperezph
Hi Guys,
May i ask if it's possible to use banana plugs for my speaker wires going to Denon AVR-1713 and TSi200, CS10, OWM3 speakers?
Thanks!
Regards,
Rodel
Thanks!
Regards,
Rodel
Denon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
Post edited by rodelperezph on
the speakers will accept them and go to the denon website to check but i believe it will2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
thanks, seabeerob213!Denon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub -
Google image search confirms that the AVR-1713 will accept banana plugs.
Monster AVL-300, HTS-2500 MKII -
Hi Syndil,
Yes, it accepts banana plugs.
Thanks!Denon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub -
I have the 1712 and yep banana plugs are no problem!
Any disadvantage to using bananas to input to the receiver?
As I was hooking up my speakers last night, it dawned on me that using bananas on BOTH connection ends would be so much easier.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
NoneSpeakers: SDA-1C (most all the goodies)
Don't try and put them in sideways or you'll break you're posts! :biggrin:
I'm not trying to be difficult but aren't banana plug compatible speakers pretty obvious just by looking at them? Am I missing something?
And for those who don't use banana plugs you don't know what you're missing. Switching back and forth between speakers you are testing is beyond easy compared to the old fashion way. Once you go banana you'll never go back. :cheesygrin: -
Thanks for this thread. I also always wondered if there was any disadvantage in using banana plugs and I have always connected my Polk Monitor speakers the old fashioned way, winding the speaker wire around the speaker terminals on the back of the speakers. What a pain! haaaa. I will get some banana plugs.
Are they all the same or are some banana plugs better or easier to use than others?
Too bad my Yamaha CR 2020 won't also take banana plugs! But at least I can use them for my speakers from now on!
Thanks again. -
Thanks for the info. I appreciate it and will get some banana plugs!
+1 -
williamHerm24 reported
In my experience Banana plugs are very usefull. It's very easy to plug and unplug your speakers, but have in mind that you need to be sure bananas gets tight into the speaker.
In my system I have GLS-audio Banana plugs locking series, in both sides of the speakers wires, and I'm happy with the them so far.
Good luck and enjoy your experience.Marantz NR1603, Marantz UD5007, Polk TSi400, Cambridge phono pre, Yamaha YP-B4 TT, Audioquest cables. -
I like banana plugs because it saves a ton of time when you have to move thing (cleaning, upgrades, etc), as Alvaro mentioned, the GLS locking plugs rock, they are a bit bulky, but if you take time and connect them evenly, they look quite nice. I went all out and even applied braided sleeving over the speaker cable for my fronts.
I have heard that the best line of transmission is a direct one, and banana plugs add unnecessary junctions for the audio signal... I can hear no difference.
One work of caution, if you have small children and locking banana plugs they may be able to topple bookshelf speakers resting on stands/shelves.
