Banana Plugs
rodelperezph
rodelperezph Posts: 14
Hi Guys,
May i ask if it's possible to use banana plugs for my speaker wires going to Denon AVR-1713 and TSi200, CS10, OWM3 speakers?
Thanks!
Regards,
Rodel
Denon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
Post edited by rodelperezph on
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited November 2012
    the speakers will accept them and go to the denon website to check but i believe it will
  • rodelperezph
    thanks, seabeerob213!
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
  • Syndil
    Syndil Posts: 1,582
    Google image search confirms that the AVR-1713 will accept banana plugs.
  • rodelperezph
    Hi Syndil,
    Yes, it accepts banana plugs.
    Thanks!
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
  • slider2828
    slider2828 Posts: 118
    edited December 2012
    I have the 1712 and yep banana plugs are no problem!
  • badchad
    badchad Posts: 348
    Any disadvantage to using bananas to input to the receiver?
    As I was hooking up my speakers last night, it dawned on me that using bananas on BOTH connection ends would be so much easier.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • thsmith
    thsmith Posts: 6,082
    None
  • codyc1ark
    codyc1ark Posts: 2,539
    Don't try and put them in sideways or you'll break you're posts! :biggrin:
  • theshawn
    theshawn Posts: 70
    I'm not trying to be difficult but aren't banana plug compatible speakers pretty obvious just by looking at them? Am I missing something?
    And for those who don't use banana plugs you don't know what you're missing. Switching back and forth between speakers you are testing is beyond easy compared to the old fashion way. Once you go banana you'll never go back. :cheesygrin:
  • pglbook
    pglbook Posts: 2,265
    Thanks for this thread. I also always wondered if there was any disadvantage in using banana plugs and I have always connected my Polk Monitor speakers the old fashioned way, winding the speaker wire around the speaker terminals on the back of the speakers. What a pain! haaaa. I will get some banana plugs.
    Are they all the same or are some banana plugs better or easier to use than others?
    Too bad my Yamaha CR 2020 won't also take banana plugs! But at least I can use them for my speakers from now on!
    Thanks again.
  • pglbook
    Thanks for the info. I appreciate it and will get some banana plugs!
  • astar13656
    astar13656 Posts: 164
    edited January 2013
    +1
  • ken brydson
    ken brydson Posts: 9,041
    edited January 2013
    williamHerm24 reported
  • Alvaro
    Alvaro Posts: 2
    edited January 2013
    In my experience Banana plugs are very usefull. It's very easy to plug and unplug your speakers, but have in mind that you need to be sure bananas gets tight into the speaker.
    In my system I have GLS-audio Banana plugs locking series, in both sides of the speakers wires, and I'm happy with the them so far.
    Good luck and enjoy your experience.
    Marantz NR1603, Marantz UD5007, Polk TSi400, Cambridge phono pre, Yamaha YP-B4 TT, Audioquest cables.
  • scoyne88
    scoyne88 Posts: 7
    edited January 2013
    I like banana plugs because it saves a ton of time when you have to move thing (cleaning, upgrades, etc), as Alvaro mentioned, the GLS locking plugs rock, they are a bit bulky, but if you take time and connect them evenly, they look quite nice. I went all out and even applied braided sleeving over the speaker cable for my fronts.
    I have heard that the best line of transmission is a direct one, and banana plugs add unnecessary junctions for the audio signal... I can hear no difference.
    One work of caution, if you have small children and locking banana plugs they may be able to topple bookshelf speakers resting on stands/shelves.
