Dual LSi7's vs. single LSiC
codyc1ark
codyc1ark Posts: 2,535
edited December 2012 in Speakers
Just putting a thought out, I've been thinking about giving dual 7's a run for my center. One above the TV and one below, I have some other upgrades I'd like to work on next year, but a new front stage isn't one of them. To me the C has always been a weak spot in HT, even though mine is modded. I don't have the room for dual 9's, and I'm sure I could run dual C's, but this would be the cheaper of the options. Any thoughts on this? Have you tried it? Like I said, this is just a thought as the above/below center setups get great reviews. TIA.
Post edited by codyc1ark on
    txcoastal1 Posts: 13,500
    I believe DK if I remember right uses dual 9's on there sides for a center Vs LSiC
    I would think that the LSi7 would also out perform the LSiC
    EndersShadow Posts: 17,687
    txcoastal1 wrote: »
    You mean like this: http://www.polkaudio.com/images/showcase/3_845_big.jpg
    Yep you beat me to it
  • codyc1ark
    Yeah, I knew he did. Lot of real estate. 9' 'would be a different beast. Trey ran a above/below center setup IIRC, perhaps we'll hear from him.
  • Stilly74
    Stilly74 Posts: 194
    I have been considering doing that with my LsiM 703's. Minus laying them on there sides. Off a separate dedicated amp, how do you wire things up?
    Stilly74 wrote: »
    If you only have a single center output to amp, you use a RCA Y-cable but you still need 2 amp outputs for speakers
