RTI12 Used - Should I buy?
dertitan2
dertitan2 Posts: 10
edited December 2012 in Speakers
I found a pair of RTI12, used, but in perfect condition for $400..I have always wanted a set of floor speakers to complete my HT, right now I have (4) TSI100 for front and side L & R, a CS10 as my center, and a PSW110 for the sub, my receiver is a pioneer VSX-94TXH...
I am a novice when it comes to this stuff, so is it worth purchasing these RTI12?? Price seems good if they are still in good condition?
I have never been completely happy with my systems sound, so I thought this addition might make an impact, but my concerns are the center channel - with these floor speakers, will it get lost and what about my current sub...lost in the mix...and do I have enough power in this pioneer elite receiver to even drive these things?
Any thoughts would be appreciated
Post edited by dertitan2 on
  • BigDaveyL
    BigDaveyL Posts: 36
    The issue is this: Does the CS10 match the RTI12 if you're using them as Front L/R.
    If you're using them as surrounds, they probably would be overkill.
  • dertitan2
    dertitan2 Posts: 10
    i thought about that, what do you suggest?
  • tommyt21
    tommyt21 Posts: 685
    dertitan2 wrote: »
    You can always timbre match at a later date with upgrades, those are a huge step up from your current fronts and would probably push you further down the rabbit hole.
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • nhhiep
    nhhiep Posts: 877
    i paid 400 for my used set as well. i don't think it's hard to resale if i change my mind now.
  • dertitan2
    dertitan2 Posts: 10
    Rabbit hole as Money Hole??? I think I understand...so my next upgrade would be a better center channel, of course then followed by better surrounds...rears...sub....etc. etc. etc.. WOW...so let me ask you, at this price point and if they are in good shape, worth buying anyway?
  • deronb1
    deronb1 Posts: 5,021
    The 12s are great for HT. I sold mine for 350.00, but 400.00 is not bad. Your AVR is not going to let them reach their potential however. That said, they will still sound good for HT. An external amp of 200wpc or more is ALWAYS a good idea for a speaker that can handle 500 wpc.
  • tommyt21
    tommyt21 Posts: 685
    I have the newer version of the rti8's (A7's) and they were well worth getting. Can you audition them? Also these things are freaking monsters they are very large. I think its worth it.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • la9ers
    la9ers Posts: 117
    if you decide to go with the rti'12 you better start saving some $$ for an amp to get the most out of them, if not i would not bother picking them up.
  • Geoff4rfc
    Geoff4rfc Posts: 2,842
    dertitan2 wrote: »
    Rabbit hole as Money Hole???....so let me ask you, at this price point and if they are in good shape, worth buying anyway?
    Oh yeah, you will quickly see that the rabbit hole has no bottom as you continually fall and fall and fall......okay, enough of that:mrgreen: Yes, that sounds like a good deal and maybe you can make an offer. As Tommy suggested, try to demo them before making a purchase.
    You're right, the center would be your next upgrade, the CSi5 or the CSiA6, either would do great. And, when you can, adding power would be the thing to do.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • Sherardp
    Sherardp Posts: 8,038
    I would pick them up at that price. Huge speakers and they perform very well. I have a set in my dedicated theater, and can't find a reason to upgrade them. Go for it, but as mentioned prepare to buy the CSiA6 center and an amp sooner or later.
  • -Stanley-
    -Stanley- Posts: 44
    If I ran across a pair of RTI12's for $400 I would jump on them. I should be so lucky.
  • dertitan2
    dertitan2 Posts: 10
    an external amp for a HT is some what foreign to me...i have external amps on my car systems...but not familiar with the brands out there for this piece of equipment...any suggestions? wish money was no option, but it is...
  • dertitan2
    dertitan2 Posts: 10
    I have another question on these RTI12...since my pioneer AVR is setup for a 7.1 system...I know that I can utilize my rear surround amp for a bi-amp setup...after reading several articles on bi-amping, i think I am more confused than educated...
    if I leave out the rear surround, and bi-amp these RTI12...does this benefit me at all...or just go with the full 7.1 setup since I know how enough speakers to do so...
    tonyb Posts: 33,072
    dertitan2 wrote: »
    Eh, not really. It's more so a marketing gimmick. What your actually doing is robbing alittle power from each of the other channels to power that bi-amp feature. Digital amps, or ice amps as they are called, found in receivers such as the Pioneer SC series tend to hold their power better when spread over 5 or 7 channels. Which is why we usually recommend those receivers when driving towers or multiple tower speakers. Aside from an external amplifier of course which would be optimal.
  • dertitan2
    dertitan2 Posts: 10
    this issue of adding an external amp, if my AVR is able to provide 140 watts per channel, over 7 channels...the type of amp that would be higher than that and over 7 channels...were talking about several thousand dollars...or am I missing something? Can you give me a model number of an amp that you may be referring to...Thx
  • dertitan2
    dertitan2 Posts: 10
    tonyb wrote: »
  • chumlie
    chumlie Posts: 8,658
    You don't need a 7 channel power amp. A high current 2 channel power amp to drive the 12's is all you need to bring those to another level. Leaving your Pioneer to drive the rest of your speakers leaving more headroom for your other speakers. Used Parasound amp can be had for around $400. I use a Parasound HCA1500a with great results.
  • dertitan2
    dertitan2 Posts: 10
    chumlie wrote: »
    I need to upgrade my center channel speaker...so should I look for a 3 channel...or will my AVR drive the center along with the other channels just fine with no additional amp needed
  • chumlie
    I think that Pioneer would handle it just fine.
  • dertitan2
    dertitan2 Posts: 10
    so a 2 channel amp like this, or do I need to go higher?
    Onkyo M-282 Stereo Amplifier 140 Watts per channel, 2 channel
  • chumlie
    I would go higher. Ebay is your friend. Used Parasound, Adcom, Carver etc 200 watts a channel. IMHO
  • slider2828
    slider2828 Posts: 118
    Would definitely jump on it
  • chadam44
    chadam44 Posts: 68
    Definitely grab the speakers as that seems to be a pretty solid deal. You will definitely want some extra power though. If you don't find anything used, emotiva has some pretty decent options (new to boot) that are not overly expensive, and since your Pio Elite 94 has pre-outs and decent power, I would just shoot for a 2 channel amp and let the receiver do the work for the center and surrounds.
  • thsmith
    thsmith Posts: 6,082
    Thats a great deal, get with Gadabout, he had the best sounding 12s I have heard but it was the amp that made the difference. B&K I think. 12s really need more current than your AVR can generate.
