Sound Dampening Foam questions
vulcan
vulcan Posts: 99
edited March 2013 in DIY, Mods & Tweaks
Has anyone used some of the sound abatement foams like NoRez or Sonic Barrier
inside their SDA model speakers and where did you place it? Did you think it helped improve the
sound quality? I think I want to use some NoRez in mine, the reviews are good.
If you have pics too that would be great, thanks.
Craig
Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
Post edited by vulcan on
    pitdogg2 Posts: 27,066
    edited December 2012
    get you search on there are several folks who have done just that most with favorable results.
  • drumminman
    drumminman Posts: 3,396
    I've not used No Rez, but I've read that it's good.
    What I did use is Black Hole. See my write up here: http://www.polkaudio.com/forums/showthread.php?128159-Black-Hole&highlight=black+hole+TF66
    It absolutely improved the sound of both my 2.3TL's and RTA 12C's, de-congesting the midrange - didn't know it was congested till I heard the speaks with the BH installed. I highly recommend this stuff.
    I wouldn't waste money on sonic barrier.
  • Conradicles
    Conradicles Posts: 6,343
    edited March 2013
  • thsmith
    thsmith Posts: 6,082
    edited March 2013
    I used norez and placed it in 3" strips behind the MW and tweeters keeping the factory fill in place.
    I had done several other upgrades when I did this but I recall that the bass had improved texture and increased punch.
  • Conradicles
    edited March 2013
    thsmith wrote: »
    Thanks thsmith! How did you come to the conclusion to use that amount? Did some other polkies try that as well with good results?
  • thsmith
    edited March 2013
    I was cheap and bought one sheet and that is how it worked out dividing the material between 2 speakers and it seemed others who went down this path before had over did it with BH5 and found less was better.
    I suppose in theory with norez you could do the most if not the entire cabinet with no ill effects.
    Toolfan66 Posts: 18,070
    edited March 2013
    YEP!! 3" strips behind the drivers and 2" strips along the side walls behind the drivers as well is what I did and love it!!!
    BTW I used BH5. I have wanted to try no rez for sometime but have not had the project for it just yet..
    VR3 Posts: 29,442
    edited March 2013
    No Rez is a great product.
    The only thing I caution against is putting it too close to the midbass drivers, do not crowd the drivers.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2013
    Toolfan66 wrote: »
    I used Black Hole 5 behind the mids (one 4" strip behind each) and along the sides (one 2" strip on each side) in my SDA SRS1.2s. I cannot comment on what precisely the effect was, because I implemented several mods at once. Overall clarity and distnctness of midrange was definitely improved.
    Here's a picture:
    I second Toolfan's "Trey for Polkie of the year!"
  • zingo
    zingo Posts: 11,258
    edited March 2013
    I've just used regular, soft foam and it helped absorb the back wave on the mid drivers to provide a cleaner sound.
    edited March 2013
    Here's a picture:
    That is exactly how I have mine..
