THIEL CS2 Coherent Source
Irrenhaus
Irrenhaus Posts: 1,105
edited December 2012 in Speakers
Hello:
So for some time I have been thinking of getting another set of main's for stereo listening only. Have RTi12s and love them. Took a look at some SDA's lately but the finish on the cabinets was not good and not sure if my amps are common ground (but I will find out for sure).
Now came across on this one's, but not sure if the price is right for them. I have always like the way they look.
http://sfbay.craigslist.org/eby/ele/3441613127.html
cheers
:neutral:
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
  • rromeo923
    rromeo923 Posts: 1,513
    I dont know if that is a good price. Its seems a little "HIGH" ??
    Anyone who sells something for "$420" is most likely a pot head. Not that there is anything wrong with that.
    I got static in my head
  • cstmar01
    cstmar01 Posts: 4,424
    I own these speakers. They are coherent that is for sure, however I paid 100 bucks or so but not nearly in the condition. normally I see around 200-250 in good condition.
    They have a lot of high end to them, and I found to be very bright but a different sound than other speakers. They do not have really any low bass. They have bass, but not really anything that digs super low and I would recommend pair with a sub if you are seeking a bass response like the RTi12's (I've owned the 9's and driven both in the same room etc).
    Fun speaker and image really well. The room size is important for these and there was a discussion awhile back on Agon about placement for these in their forums.
    F1nut Posts: 52,000
    My thoughts exactly.
  • Irrenhaus
    Thanks all for the reply's. They did seem over price for me too. I saw a pair on flebay for 149.00, I guess the hunt still on for a set.
    Cheers
  • nspindel
    nspindel Posts: 5,343
    I remember hearing Thiels way back when I was auditioning speakers when I bought my first SDA's in 1989. My impression of them was that they are incredible for classical music. Image well is an understatement. Properly set up and powered, you can pinpoint every individual instrument in an orchestra. It was mind-blowing. But I wouldn't recommend them for pop, though.
