5 1/4 midbass driver, to fit a B&W rock solid
seabeerob213
seabeerob213 Posts: 1,843
edited January 2013 in Wanted (WTB) Classifieds
i ordered a B&W rock solid monitor, and while the seller says it was working, it arrived broken, i'd believe him, but he doesnt want it returned and he lied about it being made in the UK, i clearly is labeled made in taiwan, well regardless of tha, i have a speaker that needs a driver, its a three screw design, and screws in from the back
Post edited by seabeerob213 on
  • deronb1
    deronb1 Posts: 5,021
    edited December 2012
    parts express has a ton of reasonably priced drivers
  • seabeerob213
    they dont have one that fits, that three screw set up has me looking hard, may buy another used one and hope for better luck with the driver, the driver sits in a molded slot so making a different one work is not easy
  • zingo
    zingo Posts: 11,258
    Is the driver all that's broken? If not, you will be spending more money than that speaker is worth...
  • seabeerob213
    yeah, only the driver,
  • 20hz
    20hz Posts: 636
    edited January 2013
    look at ebay or parts express I recomend buying a pair so the sound will match per side , the 3 screw may be hard to find .
    Did you buy the moniters on ebay ? did you get a refund ?
    if so you got ebay buyer protection
