Pairing Polk Rc85I and CSIA6 with Bose Acoustimass Sub
One4brett
One4brett Posts: 2
edited December 2012 in Speakers
I am slowly moving out my bose acoustimass 5.1 system for new Polk speakers. I am installing RC85i's for the front Left and Right, CsiA6 for center and Rc80i for rear L/R. for now I am keeping my Bose Acoustimass powered subwoofer, and need to know if I can avoid running my speakers to the sub before the reciever. I have a yamaha A720. Not sure the effect not routing the speakers through the sub will have on sound. Any advice would be great.
thanks
Post edited by One4brett on
  • specd_out
    specd_out Posts: 505
    yes. the acoustimass has a lfe plug that you can use. you dont have to have everything go to it. dump that sub asap. It straight junk. The most entry level polk sub will walk all over it. I dont even know if its considered a true sub. To me its more of a bass module with a lfe connection, because it only uses 2 6.5" woofers
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • One4brett
    One4brett Posts: 2
    Great. Yes, my plan is to dump the entire Bose set up in time. Can you tell me what the LFE plug does?
  • Willow
    Willow Posts: 11,234
    Your centre speaker has the same size drivers as the "bass module" does. Doesnt say much for it.
  • jbooker82
    jbooker82 Posts: 1,627
    One4brett wrote: »
    It is just a single analog input called Low Frequency Effects (LFE). The only sound that will be transmitted to the sub using LFE is from 0-120hz, not full range audio. You use a single analog cable to go from the subwoofer pre output on your Yamaha AVR to the LFE on your sub. Some subs have a Left and Right analog input (red and white rca plugs) where one is also labled LFE. You just use one cable connected to the LFE rca plug, and some times there is a switch to designate weather your using both L&R analog inputs or the single LFE.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
