lSI15, RTI12 OR RTIA9 FOR 24 X 24 THEATER ROOM ONLY
  • snake1
    snake1 Posts: 567
    edited December 2012
    Geoff4rfc wrote: »
    Okay Dave, let's see it this will help. I have a 7.2 AVR and two different amps. The AVR is rated @ 135wpc with only 2ch driven. My amps are rated @ 200wpc and 300wpc all channels driven. My 300w feeds 2 speakers, the 200w feeds 3 speakers and the AVR feeds 2 speakers. I have a speaker set up mic with my AVR and it does room correction and calibrates the speakers so even though different speakers are getting different power ratings, everything is blended and sounds great together.
    Almost all AVR's are rated with two channels driven, once you add more channels, the power drops. Like mentioned before, mine is rated @ 135wpc 2 ch driven. 105wpc with 5 ch driven, and when I use all 7 channels, I'm pushing a lowly 29.9wpc.
    This is why there's a need for power amps. Most AVR's do not sustain max power through all channels.
    Not trying to hijack but Geoff, can you explain how you figure your AVRs wattage when driving more than 2 speakers??
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
    F1nut Posts: 51,809
    snake1 wrote: »
    You can find reviews at various sites were folks test those things because the AVR manufacturers rarely tell the entire truth.
    F1nut Posts: 51,809
    sagasa wrote: »
    get emotiva xpa3 you wont regret it..
    And you know this because you've tried other amps first?
  • gp4jesus
    gp4jesus Posts: 2,019
    Geoff4rfc wrote: »
    Great post, dude! I think some (or all) of the Pioneer SC series & all Rotels AVRs are exceptions to what you described w/the Rotel$ rated to 4 ohm$.
    Hang in there, Dave. Don't rush into (a) purchase(s).
    *all connected w/Premiere ICs
  • sagasa
    sagasa Posts: 127
    I like two and the three amps than xpa5 for simple reason if one breaks i have a back up.
    Front: Tekton Pendragon
    Center: Tekton Pendragon
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
