Value of RTA-12C
factorz
Well since picking up my SDA-1C I have found very little use for my RTA's and wanted to get some feedback on value. They have been fully modded by VR3 including Sonic Barrier, Dynamat, and JB Weld. I know I won't get what I put into them, but also feel such great speakers should start getting some use. Thanks.
Post edited by factorz on
I'm assuming that VR3 also upgraded the crossovers? What brand components? RD0's? Condition?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Yeah VR3 did the crossovers and the ones on his site are actually mine. I did upgrade to the new RDO's, but will most likely swap these out to use in the SDA's. As for condition I would consider them good.
You need to provide more information:
Did he upgrade both upper and lower Xovers?
List components used
Which tweeters will be included
Pics
Tough to give you an informed estimate on value without the above."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
My bad guys. The stock tweeters will be included.
Parts List -
Tweeter Circuit -
ERSE Pulse X Capacitors
ERSE Non-Inductive Resistors
Midbass Circuit -
Upgrade Features -
XLR Connection from top to bottom cabinet
Upgraded Wiring -
Where is Gamehenge?--Gary--
Not familiar with the erse caps and resistors - perhaps someone who is will chime in.
I rebuilt mine with sonicaps and mills, + some other mods, about $600 worth of parts. I would hope to get $350 for them, though I would let them go for less to Polkie. Would they sell for that? Who knows. . ."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
