Value of RTA-12C
factorz
factorz Posts: 353
edited December 2012 in Vintage Speakers
Well since picking up my SDA-1C I have found very little use for my RTA's and wanted to get some feedback on value. They have been fully modded by VR3 including Sonic Barrier, Dynamat, and JB Weld. I know I won't get what I put into them, but also feel such great speakers should start getting some use. Thanks.
Post edited by factorz on
  • falconcry72
    falconcry72 Posts: 3,580
    I'm assuming that VR3 also upgraded the crossovers? What brand components? RD0's? Condition?
  • factorz
    factorz Posts: 353
    Yeah VR3 did the crossovers and the ones on his site are actually mine. I did upgrade to the new RDO's, but will most likely swap these out to use in the SDA's. As for condition I would consider them good.
  • drumminman
    drumminman Posts: 3,396
    You need to provide more information:
    Did he upgrade both upper and lower Xovers?
    List components used
    Which tweeters will be included
    Pics
    Tough to give you an informed estimate on value without the above.
  • factorz
    factorz Posts: 353
    My bad guys. The stock tweeters will be included.
    Parts List -
    Tweeter Circuit -
    ERSE Pulse X Capacitors
    ERSE Non-Inductive Resistors
    Midbass Circuit -
    Upgrade Features -
    XLR Connection from top to bottom cabinet
    Upgraded Wiring
  • halo71
    halo71 Posts: 4,606
    Where is Gamehenge?
    --Gary--
  • drumminman
    Not familiar with the erse caps and resistors - perhaps someone who is will chime in.
    I rebuilt mine with sonicaps and mills, + some other mods, about $600 worth of parts. I would hope to get $350 for them, though I would let them go for less to Polkie. Would they sell for that? Who knows. . .
