First time post. Im not sure how this stuff works but I wanna upgrade my audio setup
wachiga
wachiga Posts: 8
Hey there, I currently own basic computer speakers that run through the green 3.5mm plug and they def need to be replaced with something that can handle music with low freq. I was looking at the Polk PSW10 and the 35B Monitors but would I need to buy a receiver or can I just get adapters? On the back of my computer I only have 6 analog(orange.blue.green pink), and S/PIDF IN/OUT. Any help is appreciated. Thank you
Post edited by wachiga on
  • wachiga
    wachiga Posts: 8
    edited December 2012
    Any help is greaty appreciated. The sale for this sub is almost over so i need answers!!!
  • Geoff4rfc
    Geoff4rfc Posts: 3,011
    Hey wachiga, welcome to the club!
    So you've got a PC and some PC speakers. What size is your room, what overall goal are you trying to achieve and what kind of budget are you working with?
  • Geoff4rfc
    Also, it this is just for your computer, you might consider adding a small receiver to get some power going to those monitors.
  • wachiga
    wachiga Posts: 8
    My room is about 10' X 15'. And yes these will only be used as my computer speakers for music. I listen to techno so responsive and clear bass is necessary. Budget is $200 for speakers/sub. Newegg is selling the PSW10 for $80 and the M30 for $80 as well. I don't really want a receiver as those are expensive. And thank you for your reply
  • Geoff4rfc
    Sounds like a good plan! Yeah, the sub has it's own amp, so if your computer can drive those monitors, you're set.
    I've owned the Monitor 30 series II which is basically the same, great speaker.
  • wachiga
    wachiga Posts: 8
    How do I know if my computer can drive the M30s? I have no idea how these would be connected to my computer at all. Would it go from the speakers to the sub via 5way bindng then from the sub to the computer with RCA to 3.5mm?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    You'll need a receiver or amp to drive speakers unless they are self powered.
  • wachiga
    wachiga Posts: 8
    Is it possible to get a simple receiver for like $50?
  • AsSiMiLaTeD
    Maybe check around on Craigslist, not gonna find that in a store though. With a budget in that range I'd recommend looking at a good set of powered speakers instead. Check out audio engine and swan speakers.
  • wachiga
    wachiga Posts: 8
    I was trying to spend a maximum of $200 on the whole setup. So if M30s and PSW10 are $160 total then that doesnt leave me with much
  • Geoff4rfc
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882120194
    I don't know of anything that cheap unless you hit the right garge sale. Check the link above.
  • AsSiMiLaTeD
    wachiga wrote: »
    if that's your budget then I'll stick with my recommendation to check out powered speakers.
  • wachiga
    wachiga Posts: 8
    Those powered speakers dont drop low enough in freq for me to not get the subwoofer
  • blehmbo
    blehmbo Posts: 179
    As the folks recommended above, you will want a AV receiver to power the speakers. You could find an older receiver fairly cheap. Ideally the receiver will have spdif or toslink (optical) inputs, if your PC has outputs for them, otherwise you could could connect your pc by using 3.5mm to RCA adapters (not preferred). Outdated AV receivers tend to devalue quickly once they become outdated (no HDMI). If you still cant find a receiver cheap enough you could try to find a used psw10 to fit the budget.
    With a quick search of my local craigslist I was able to find:
    Marantz SR4400 AV receiver - $75
    Harmon Kardon Receiver/AMP (AVR 310) - $75
    Yes, they are a bit out of your price range, but you may be able to find something that fits with a bit of searching or saving.
  • Geoff4rfc
  • wachiga
    wachiga Posts: 8
    But I dont need a home theater receiver. I will only be using 1% of its capabilities. So theres no cheaper alternative huh?
  • blehmbo
    blehmbo Posts: 179
    I don't think you will find anything cheaper than an AVR, maybe with the exception of a stereo receiver.
  • rooftop59
    rooftop59 Posts: 8,120
    http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-383
    The above might work for you. It's what I use in my computer rig and it actually sounds pretty darn good in a modest nearfield rig. It would be slightly over budget but about as close as you'll get. The key is that the psw10 needs a high pass filter for the setup to really work which I am not sure that is. It'll work without it but not as well.
    good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • Geoff4rfc
    Yeah, I'm afraid it's not quite as easy as you were hoping BUT.......on the plus side, if you did go with a small AVR and your PC has a bluray player, you're set up for both music and movies with a very nice audio section. Even it's only DVD, you're still good to go.
  • rooftop59
    rooftop59 wrote: »
    good luck!
    Or if you really need to keep it under 200, go with something like this:
    http://www.amazon.com/Klipsch-ProMedia-Certified-Computer-Speaker/dp/B000062VUO/ref=sr_1_1?ie=UTF8&qid=1354482236&sr=8-1&keywords=klipsch+promedia
    I used these for my bedroom setup for some time, and its a rockin (though not very refined) little setup. The sub puts out more bass than the PSW10 will, allow the sats will not sound as refined as the polks. The only reason I got rid of it at the time was that it had no remote, so I had to get up to adjust the volume. For a computer setup you obviously wouldn't have that problem.
    Game Room 5.1.4:
    Bedroom 2.1
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    rooftop59 wrote: »
    I was going to suggest those klipsch as well. Check out edifier too they are gaining popularity and sound pretty good too.
    http://www.amazon.com/Edifier-USA-M1380-Multimedia-Speakers/dp/B004N31D9W/ref=sr_1_fed1_1?ie=UTF8&qid=1354714609&sr=8-1&keywords=edifier+speakers
