Receiver suggestion for RTIA7
kbob456
Hi Folks
I recently got below speakers.I was thinking of receiver Marantz SR 6007,Does it drive the speakers are do i need to get higher power one.Any other receiver sugesstions for RTIA7's?
1 PAIR RTIA7 BLACK
1 EACH CSIA6 CENTER BLACK
1 PAIR FXIA6 BLACK
1 DSWPRO660IW
Thanks,
Bob
1 PAIR RTIA7 BLACK
1 PAIR FXIA6 BLACK
1 DSWPRO660IW
Thanks,
Bob
Post edited by kbob456 on
Pioneer Elite SC series, perfect match for what you have.Political Correctness'.........defined
President of Club Polk -
Thanks ,Any recommendation on Watts.Do i need to get a separate amp as well...
How about and UMC-200 and XPA-5 from Emotiva.
My 2cents.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
+1 i am running a sc 27 on rti12 with no problems at all. In my room no need for a separate amp.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Same with the SC-35, they're a great match. -
+1 over the Marantz 6007. The Pioneers have a consistant "all channels driven" rating. Not the Marantz. Other members can chime in on the SCs' ability to handle (the RTi A7's*) 4* ohm* load(s).Pioneer Elite SC series, perfect match for what you have.
* website is wrong
Merry Christmas, TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
* website is wrong
Where did you come up with that info?Political Correctness'.........defined
I use a Pioneer SC-35 for home theatre with RTi10's ( Previous model to the RTiA7 ) RTiA6 center and RTi4 surrounds. I easily get powerful sound without having to push the Receiver close to maximum. And my room is a good size,so you should be ok unless you have a hugh room and like it REALLY LOUD.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
Not sure where your located at but, this is a great deal in the chicago land area http://chicago.craigslist.org/nch/ele/3431871969.htmlKlipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I pretty much have your setup and I'm using the Yamaha I have in my sig below with no problems! With the exception that mine are Cherry and White which require less power. :razz:Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Thanks,In Boston..
Other members can chime in on the SCs' ability to handle (the RTi A7's*) 4* ohm* load(s).*
* website is wrong
Where? From studying the XO.Where did you come up with that info?
They might be "nominally" 8 ohms, but below 125hz they're 4 ohms.
Last time I checked two 8 ohm impedance paths (IP) in parallel, net 4 ohms, right?! And the low end is tough enough to drive w/out the impedence drop.
For those who thrive on details:
1. two 4 ohm impedances in series = 8 ohm IP. Connect that IP in series w/a 2nd order LP 125hz filter nets 8 ohms below 125hz
2. another 8 ohm IP, in series w/a 2nd order LP 2.7Khz filter, ZERO HP filtering, nets 8 ohms below 2.7Khz
Trey (VR3) and a few others that have seen/modded the XO will concur.
IP#1 in parallel w/IP#2 nets 4 ohms below 125hz really challenging low current amp/AVRs particularly those not sporting a 4 ohm spec. So unless you know something I don't or someone can provide hard data that refutes these facts, most AVR owners should either XO 'em @/above 100hz or, dare I say it, passively bi-amp 'em - either will lighten the "load." [sic]
What???? I know December's close but it's not here yet!!
Alright then, merry Christ mas.Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
That doesn't make them 4 ohm loads. To be a rated 4 ohm speaker the majority of the impedance would have to be at or below 4 ohms. Most, if not all speakers have impedance drops lower than their nominal rating. IIRC, at least one of the bigger SDA's drops to 2 ohms at some point, but it is still rated as a nominal 6 ohm speaker.
As for the RTiA7's, I drive mine with a Pioneer Elite SC-37 crossed at 80Hz with no issues whatsoever watching Blu-ray movies and the occasional music video at high volume levels. I've even run them full range for 2 channel music without issue, but what's the point of that when I've got other rigs that are much better for 2 channel.Political Correctness'.........defined
gp4Jesus wrote:Other members can chime in on the SCs' ability to handle 4 ohm loads.
Per F1, the SC series can!I drive my RTiA7's with a Pioneer Elite SC-37 crossed at 80Hz with no issues whatsoever watching Blu-ray movies and the occasional music video at high volume levels. I've even run RTiA7's full range for 2 channel music without issue.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Thanks for suggestions,ended up buying pioneer elite sc 65.
Wicked receiver, congrats.Shoot the jumper.....................BALLIN.............!!!!!
My Dad bought an SC-65 as well. We're doing some system upgrades this weekend, so I'll get to see how it compares to my SC57. Either way, it'll be a nice upgrade from his Onkyo 707.
Do post your thoughts on the receiver kbob! Congrats.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
