Receiver suggestion for RTIA7
kbob456
kbob456 Posts: 4
edited December 2012 in Electronics
Hi Folks
I recently got below speakers.I was thinking of receiver Marantz SR 6007,Does it drive the speakers are do i need to get higher power one.Any other receiver sugesstions for RTIA7's?
1 PAIR RTIA7 BLACK
1 EACH CSIA6 CENTER BLACK
1 PAIR FXIA6 BLACK
1 DSWPRO660IW
Thanks,
Bob
Post edited by kbob456 on
    F1nut Posts: 52,264
    edited November 2012
    Pioneer Elite SC series, perfect match for what you have.
  • kbob456
    kbob456 Posts: 4
    Thanks ,Any recommendation on Watts.Do i need to get a separate amp as well...
  • Irrenhaus
    Irrenhaus Posts: 1,105
    How about and UMC-200 and XPA-5 from Emotiva.
    My 2cents.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • erniejade
    erniejade Posts: 6,321
    +1 i am running a sc 27 on rti12 with no problems at all. In my room no need for a separate amp.
  • B Run
    B Run Posts: 1,888
    erniejade wrote: »
    Same with the SC-35, they're a great match.
  • gp4jesus
    gp4jesus Posts: 2,019
    +1 over the Marantz 6007. The Pioneers have a consistant "all channels driven" rating. Not the Marantz. Other members can chime in on the SCs' ability to handle (the RTi A7's*) 4* ohm* load(s).
    * website is wrong
    Merry Christmas, Tony
    *all connected w/Premiere ICs
    F1nut Posts: 52,264
    * website is wrong
    Where did you come up with that info?
  • larry777
    larry777 Posts: 480
    I use a Pioneer SC-35 for home theatre with RTi10's ( Previous model to the RTiA7 ) RTiA6 center and RTi4 surrounds. I easily get powerful sound without having to push the Receiver close to maximum. And my room is a good size,so you should be ok unless you have a hugh room and like it REALLY LOUD.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • erniejade
    Not sure where your located at but, this is a great deal in the chicago land area http://chicago.craigslist.org/nch/ele/3431871969.html
  • gce
    gce Posts: 2,158
    I pretty much have your setup and I'm using the Yamaha I have in my sig below with no problems! With the exception that mine are Cherry and White which require less power. :razz:
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • kbob456
    kbob456 Posts: 4
    Thanks,In Boston..
  • gp4jesus
    Other members can chime in on the SCs' ability to handle (the RTi A7's*) 4* ohm* load(s).*
    * website is wrong
    Where? From studying the XO.
    They might be "nominally" 8 ohms, but below 125hz they're 4 ohms.
    Last time I checked two 8 ohm impedance paths (IP) in parallel, net 4 ohms, right?! And the low end is tough enough to drive w/out the impedence drop.
    For those who thrive on details:
    1. two 4 ohm impedances in series = 8 ohm IP. Connect that IP in series w/a 2nd order LP 125hz filter nets 8 ohms below 125hz
    2. another 8 ohm IP, in series w/a 2nd order LP 2.7Khz filter, ZERO HP filtering, nets 8 ohms below 2.7Khz
    Trey (VR3) and a few others that have seen/modded the XO will concur.
    IP#1 in parallel w/IP#2 nets 4 ohms below 125hz really challenging low current amp/AVRs particularly those not sporting a 4 ohm spec. So unless you know something I don't or someone can provide hard data that refutes these facts, most AVR owners should either XO 'em @/above 100hz or, dare I say it, passively bi-amp 'em - either will lighten the "load." [sic]
    Tony
  • Geoff4rfc
    Geoff4rfc Posts: 3,028
    gp4jesus wrote: »
    What???? I know December's close but it's not here yet!!
    Alright then, merry Christ mas.
    F1nut Posts: 52,264
    That doesn't make them 4 ohm loads. To be a rated 4 ohm speaker the majority of the impedance would have to be at or below 4 ohms. Most, if not all speakers have impedance drops lower than their nominal rating. IIRC, at least one of the bigger SDA's drops to 2 ohms at some point, but it is still rated as a nominal 6 ohm speaker.
    As for the RTiA7's, I drive mine with a Pioneer Elite SC-37 crossed at 80Hz with no issues whatsoever watching Blu-ray movies and the occasional music video at high volume levels. I've even run them full range for 2 channel music without issue, but what's the point of that when I've got other rigs that are much better for 2 channel.
  • gp4jesus
    gp4Jesus wrote:
    Other members can chime in on the SCs' ability to handle 4 ohm loads.
    I drive my RTiA7's with a Pioneer Elite SC-37 crossed at 80Hz with no issues whatsoever watching Blu-ray movies and the occasional music video at high volume levels. I've even run RTiA7's full range for 2 channel music without issue.
    Per F1, the SC series can!
  • kbob456
    kbob456 Posts: 4
    Thanks for suggestions,ended up buying pioneer elite sc 65.
  • Sherardp
    Sherardp Posts: 8,038
    Wicked receiver, congrats.
  • PrazVT
    PrazVT Posts: 1,607
    My Dad bought an SC-65 as well. We're doing some system upgrades this weekend, so I'll get to see how it compares to my SC57. Either way, it'll be a nice upgrade from his Onkyo 707.
    Do post your thoughts on the receiver kbob! Congrats.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
