265-LS custom enclosures
jeadamsii
jeadamsii Posts: 1
I have a need for a specific size speaker. I would like to use the 265-LS in wall speakers mounted in a custom built enclosure. My question is can I use a 3/4" plywood or am I limited to 1/2"? Also, are their any other tips you have on speaker building? Thanks.
Post edited by jeadamsii on
    F1nut Posts: 52,164
    edited November 2012
    I would use MDF instead of plywood and yes, use thicker rather than thinner.
