WTB: CSi40 or CSi30 or any RTi38 matching center!
rnp614
Looking for a black center channel that would match ok with my RTi38 fronts/rears. Let me know what you have and what your price is SHIPPED. Thanks!!
Post edited by rnp614 on
If price isn't that big of a deal to you, I would say hold out for a good deal on a Csi40. You will definitely thank yourself in the long run, there is really a big difference between the two. Also, you won't feel compelled to upgrade later, that is if you're that sort of person (aren't we all?:D )
Sorry I don't have any leads at the moment, but if I come across anything I will post back.
Mike -
Awesome, thanks for the advice, I think i'll do that. I was about to get some RTi4s for rears, but then came across some RTi38s and got em. Hopefully I can get a CSi40 and put together a nicely matching system. I guess putting the money in now will be worth it later even if the things get worn, for they will sound better and go together!
Good choice to hold out for a 40.
When you get your center all the drivers and the tweets in your system will be identical. If you throw in a nice little subwoofer, you will be golden.
Good luck, and like I said before I'll keep an eye out. -
Until I get a CSi I guess i'll just drink a few 40's
Hey rnp--
A CSi40 just went up on ebay yesterday (no affiliation)...
good luck
H/K525avr
FrontsRT55i [bi-wired]
CenterCSi40 [bi-wired]
RearsRT38i
SubPSW404 -
I'm looking to get one off of this forum from someone who is willing to accept a money order (sent from bidpay aka western union). Plus it seems that people on this forum are more trustworthy and would probably pack it with more care?
Raj -
You are probably right--just trying to help
Personally, I've had a very positive experience with ebay...I've been dealing on there for 5+ years--yes I've had a few disappoinments, but after a while, you get an idea of whom to stay away from...
MHO, good luck anyway
H/K525avr
RearsRT38i
SubPSW404
