SDA 1 and SDA 1B (why did polk change tweeter position??)
tophatjohnny
Seeing these pop up all over the place and looking at the SDA1's the tweets are side by side on top and the SDA 1B's tweets are stacked on top of each other. Why was this change made and was it for the better?? Anyone know??
Post edited by tophatjohnny on
Original SDAs had a dimensional tweeter, not just dimensional mid driver(s). This was phased out in newer models as most of the SDA "magic" occurred in the frequencies covered by the mid drivers and there were some less-than-desirable sonic aspects with the dimensional tweeter.
Some (perhaps all?) of the SDAs with vertically arranged tweeters had them fed differently from the crossover, so they didn't all output identically. See if you can read the SDA handbook that DarqueKnight authored that VR3 has uploaded on his site. I'm by no means a guru of all things SDA, and you'll get the straight dope in that handbook.Jay
Original SDAs had a dimensional tweeter, and there were some less-than-desirable sonic aspects with the dimensional tweeter.
The SDA 2.3's have the same up and down tweeter placement, so "less than desirable" puzzles me a tad?? Really looking to see if anyone knows why the change was made from side my side placement of the tweeters to the up and down placement. That's all."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Side by side tweeters (as the original SDA 1's and CRS) had the lesser performance. 2.3's were not the "original" SDAs, and were getting close to the best SDAs Polk made. The last (TL) series had their best tweeters and perhaps improved cabinets.
Really, any of you that know more than me are free to jump in here any time...
Here, get your read on: LINKAGEJay
IIRC the stacked tweeters act as a line source with the bottom one handling the lower high end and the top one handling the upper high end.Denon PMA-900V
Linn Axis with Grado Red
Cambridge Azur 650C
Polk SDA-1BTL -
Top tweeter is full-treble-range rolled off only at the low-cut crossover frequency. Lower tweeter is more bandwidth-limited, same low cut-off as the upper, but also with a high-frequency rolloff. Progressive point source (PPS) using two tweeters, while the SRS 2.3 has a three-tweeter PPS, and the SRS, 1.2, and 1.2TL use a four-tweeter PPS array.IIRC the stacked tweeters act as a line source with the bottom one handling the lower high end and the top one handling the upper high end.
Removing the SDA tweeter is arguably "THE" single-biggest improvement among the various SDA generations. Everything made AFTER the SDA tweeter was removed is clearly a step above everything made with an SDA tweeter. Perhaps some folks will disagree. -
Great download and thank you for the straight forward answer I could make sense of! Also thanks to "bigaltx24" for slapping it down for me!
Schurkey's description is more accurate, they are a progessive point source.Removing the SDA tweeter is arguably "THE" single-biggest improvement among the various SDA generations. Everything made AFTER the SDA tweeter was removed is clearly a step above everything made with an SDA tweeter.
Agreed.Political Correctness'.........defined
President of Club Polk -
Maybe if you understand tongues??:razz:Schurkey's description is more accurate, they are a progessive point source.
