SDA 1 and SDA 1B (why did polk change tweeter position??)
tophatjohnny
tophatjohnny Posts: 4,189
edited November 2012 in Vintage Speakers
Seeing these pop up all over the place and looking at the SDA1's the tweets are side by side on top and the SDA 1B's tweets are stacked on top of each other. Why was this change made and was it for the better?? Anyone know??
Post edited by tophatjohnny on
  • agfrost
    agfrost Posts: 2,474
    Original SDAs had a dimensional tweeter, not just dimensional mid driver(s). This was phased out in newer models as most of the SDA "magic" occurred in the frequencies covered by the mid drivers and there were some less-than-desirable sonic aspects with the dimensional tweeter.
    Some (perhaps all?) of the SDAs with vertically arranged tweeters had them fed differently from the crossover, so they didn't all output identically. See if you can read the SDA handbook that DarqueKnight authored that VR3 has uploaded on his site. I'm by no means a guru of all things SDA, and you'll get the straight dope in that handbook.
    Jay
  • tophatjohnny
    agfrost wrote: »
    Original SDAs had a dimensional tweeter, and there were some less-than-desirable sonic aspects with the dimensional tweeter.
    The SDA 2.3's have the same up and down tweeter placement, so "less than desirable" puzzles me a tad?? Really looking to see if anyone knows why the change was made from side my side placement of the tweeters to the up and down placement. That's all.
  • agfrost
    Side by side tweeters (as the original SDA 1's and CRS) had the lesser performance. 2.3's were not the "original" SDAs, and were getting close to the best SDAs Polk made. The last (TL) series had their best tweeters and perhaps improved cabinets.
    Really, any of you that know more than me are free to jump in here any time... :lol:
    Here, get your read on: LINKAGE
    Jay
  • bigaltx24
    bigaltx24 Posts: 141
    IIRC the stacked tweeters act as a line source with the bottom one handling the lower high end and the top one handling the upper high end.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • Schurkey
    Schurkey Posts: 2,122
    bigaltx24 wrote: »
    Top tweeter is full-treble-range rolled off only at the low-cut crossover frequency. Lower tweeter is more bandwidth-limited, same low cut-off as the upper, but also with a high-frequency rolloff. Progressive point source (PPS) using two tweeters, while the SRS 2.3 has a three-tweeter PPS, and the SRS, 1.2, and 1.2TL use a four-tweeter PPS array.
    Removing the SDA tweeter is arguably "THE" single-biggest improvement among the various SDA generations. Everything made AFTER the SDA tweeter was removed is clearly a step above everything made with an SDA tweeter. Perhaps some folks will disagree.
  • tophatjohnny
    agfrost wrote: »
    Great download and thank you for the straight forward answer I could make sense of! Also thanks to "bigaltx24" for slapping it down for me! :wink:
    F1nut Posts: 51,997
    Schurkey's description is more accurate, they are a progessive point source.
    Agreed.
  • tophatjohnny
    Maybe if you understand tongues??:razz:
