Audyssey Do you use it?
jeremymarcinko
jeremymarcinko Posts: 3,785
edited December 2012 in Electronics
I would like to here what you folks think about Audyssey. I personally think its useful to setup levels and distance but I think the auto eq makes my movie dialog sound like its coming out of a big metal can. So I leave it off.
Post edited by jeremymarcinko on
  • thsmith
    thsmith Posts: 6,082
    edited November 2012
    I use it everytime I change out speakers or change the room. I reset the subwoofer afterwards.
    No issues.
    EndersShadow Posts: 17,703
    I use it and its gotten MUCH better since 2EQ which is what I think your model has (which my Integra DTR 5.9 also has). I have no problems with dialog at all in how things sound when I was using it with either my Monitor 60's + CS2 + Monitor 40 setup or my current LSi 15 + LSiC + LSi f/x setup.
    Its also totally dependent on how your room is setup as well as if you run it correctly and your gear. Might post some pics of your setup and or how you ran it. Maybe it can be an easy fix. It can be pretty finicky in how you run it and how it responds to things (like other loud noises, reflections/height, ect).
  • Tbone289
    Tbone289 Posts: 661
    I have MultEQ and I rerun it with any speaker changes, including placement. The only changes I make afterward are level changes, mainly to reduce rear channel volume. Overall, it does a great job of EQ'ing my system for movies.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • jeremymarcinko
    I have Multi eq XT.
  • Mystery
    Mystery Posts: 2,546
    My Onkyo is set to use Audessey all the time and I sometimes increase center level depending upon what is on but overall works great.
  • SugarmillMan
    SugarmillMan Posts: 175
    I certainly use it. I have MultiEQ XT32 and it works wonderfully. I only tweak some of the volumes and raise a couple of the bass crossover settings.
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • kuntasensei
    kuntasensei Posts: 3,263
    I had the 705 that you have and used it on that. I currently have the TX-NR1007 and still use Audyssey. If you want some detailed info on properly using Audyssey with the 705, hit AVSForum's 705 owner's thread. There's a detailed FAQ HERE with a section on Audyssey that I wrote up detailing the guidelines for a proper runthrough of Audyssey. First and foremost, USE A TRIPOD. If you aren't using a tripod or a boom mic stand to place the setup mic, you're already setting it up to fail miserably.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • SugarmillMan
    AVS also has an entire long and detailed thread just for using Audyssey.
  • jeremymarcinko
    Wow, nice read. I did use a tripod, however my furnace was probably running at the same time and I was lazy and only used 3 locations. I will try again thank you very much for that link.
  • Face
    Face Posts: 14,340
    I didn't find Audyssey impressive with the 706 or 707 either.
    That right there is your problem. Follow the directions right and it should sound better. You might need to run your center hotter.
    You are supposed to turn off everything that can make noise, including fans, AC, dogs, ect.
  • Face
    Face Posts: 14,340
    How do you turn a dog off? :cheesygrin:
  • SugarmillMan
    It seems to be important when running Audyssey to run as many microphone locations as possible. Also, I follow their recommended microphone placement guide to the letter.
  • ambiophonics
    ambiophonics Posts: 727
    I've never tried it but am tempted to, I just need to snag a denon dm-a409 mic. Does anyone know if the setup should be run with Polk SDA IC plugged in or unplugged?
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • Tbone289
    Tbone289 Posts: 661
    It should be run with your equipment in the exact configuration that you will be using. So, if you will use the system with the IC plugged in, then run Audyssey that way.
  • Tankman
    Tankman Posts: 419
    I just upgraded too a Onkyo NR818 still getting around on this unit.But can say I like it a lot.Its miles ahead of my H/K3600 that it replaced.I don't use it for music.It blended my two subs very well.
  • goofyGAguy
    goofyGAguy Posts: 545
    Face wrote: »
    My humble setup...
    ...is no more. :cry:
    Face wrote: »
    hehehehe, give em a bone, make the wife take em on a walk, kick em really hard (kidding on this one). In my case I just put a bunch of peanut butter in their Kong balls and put em in their cage. They are happy as can be to just sit there and get every last drop of PB out of it.
    I have older AVRs so I don't use it much. I rely on an SPL meter and my ears. I can't imagine that someone who is a conductor (I am NOT) would not be able to fine tune a surround system using just his ears and match or outdo the "best" Audyssey system? But not many of us have that kind of spatial hearing. So don't stop running those systems, just yet!
    cnh
  • moe
    moe Posts: 48
    I use it on upper end units, just calibrate on lower end(608 for example).The full feature suite is ok, not really better than a upper end unit with no Audyssey.The lower end version I just pass on.
  • slider2828
    slider2828 Posts: 118
    I also use odyseey when I upgrade xover's on speakers or change anything in the room.... Loved it on my Denon...
