Looking for info on speaker & crossover removal
vulcan
vulcan Posts: 99
edited November 2012 in DIY, Mods & Tweaks
Hi,
Can anyone point me to some links on pulling speakers and crossovers
with some pics. Preferably on the SDA1C. Thanks
Craig
Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
Post edited by vulcan on
  • gimpod
    gimpod Posts: 1,793
    Craig, you don't need pictures just use a phillips screwdriver to remove the screws for each driver/tweeter/passive radiator one at a time of course, pull the driver, remove and label the wires. To remove the crossover unplug the connectors and label them accordingly (P1 Input, P2 Driver Output, P3 Tweeter Output) then hold the Crossover with one hand and remove the Allen head bolt from the back of the enclosure.
  • vulcan
    vulcan Posts: 99
    ok, thanks. I will give it a go this weekend.
