Got another sub. PSW650
jdavy
jdavy Posts: 380
Stoped off at Fry's and saw this new boy sitting in the clearance section. I have the PSW505 and the PSW350. I needed another sub like a hole in my head. I wonder which will sound better, the 505 or the 650?
Post edited by jdavy on
    VR3 Posts: 29,700
    edited May 2004
    My money is on the 505.
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2004
    jdavy,
    Any results yet?
    Regards,
    PolkThug
  • jdavy
    jdavy Posts: 380
    edited May 2004
    I have both tied into the system. I have used a splitter to split the lfe output from the receiver to supply the signal to both subs. The PSW505 is the monster. It has more volume and is louder. The PSW650 is softer but playes music better. Will continue to play with it. For now I am going to continue to use both. I am toying with the idea of switching the PSW650 from LFE to speaker imput and then running the speaker wires out to the 800i's I will need to get more wire and banana plugs if I decide to go that rout. Has anyone done this yet. My thought is that I would use the 650 to add more base to the 2 channel rig and then use the 505 for the LFE for DTS and DD5.1.
    Any thoughts? Does running the left and right channel though the 650 affect the performance of the HT system?
