Suggestions for surrounds
S4vant
S4vant Posts: 2
edited November 2012 in Speakers
Hi all, looking to finish up my basement HT setup, and need some suggestions for the rear surrounds.
My setup currently consists of:
Center: CSi A6
Fronts: RTi A7
Sub: DSW Pro 550wi
Receiver: Onkyo TX-NR709
The rears need to be ceiling mounted, and unfortunately it's only 7ft high. Don't have enough room for in ceiling, so it will have to be a bracket mount. Don't know if Polk has anything small enough. I was looking at the Klipsch S-10.
Thoughts? Any other suggestions? Thanks!
Post edited by S4vant on
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    Check out the FX di/bipole series. They have dual key hole slots on the rears, could be mounted to the ceiling with some effort.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
    F1nut Posts: 51,687
    F/XiA4 or 6 would be the perfect match, so figure out a way to make them work.
  • SugarmillMan
    SugarmillMan Posts: 175
    PM sent
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • S4vant
    S4vant Posts: 2
    I think the F/XiA4's are a bit too chunky at around 12x12x7.5.
    Anyone have opinions on the OWM series?
  • jbooker82
    jbooker82 Posts: 1,627
    Well the OWM5 are 16" tall and the OWM3 are 10" tall so your only going to gain 2" of celing hight by going with the OWM3's and you will have less celing if you go with the OWM5's.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
