Suggestions for surrounds
Hi all, looking to finish up my basement HT setup, and need some suggestions for the rear surrounds.
My setup currently consists of:
Center: CSi A6
Fronts: RTi A7
Sub: DSW Pro 550wi
Receiver: Onkyo TX-NR709
The rears need to be ceiling mounted, and unfortunately it's only 7ft high. Don't have enough room for in ceiling, so it will have to be a bracket mount. Don't know if Polk has anything small enough. I was looking at the Klipsch S-10.
Thoughts? Any other suggestions? Thanks!
Center: CSi A6
Fronts: RTi A7
Sub: DSW Pro 550wi
Check out the FX di/bipole series. They have dual key hole slots on the rears, could be mounted to the ceiling with some effort.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2
F/XiA4 or 6 would be the perfect match, so figure out a way to make them work.Political Correctness'.........defined
President of Club Polk -
PM sentFronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
Subwoofer: HSU VTK3-MK3
Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp -
I think the F/XiA4's are a bit too chunky at around 12x12x7.5.
Anyone have opinions on the OWM series? -
Well the OWM5 are 16" tall and the OWM3 are 10" tall so your only going to gain 2" of celing hight by going with the OWM3's and you will have less celing if you go with the OWM5's.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
