how to hook up subwoofer with no sub out on amp
Neale13
Neale13 Posts: 88
i want to add a sub.my pre amp has 2 sets of outputs .no sub outputs. with one set feeding 1 amp,the other set feeding another amp.i thought i could split on of the outputs on the pre amp and run a set of rca cables to the sub. guy at best buy told me that will not work.that i need a deticated subwoofer output from my pre amp. the guy from crutchfield told me i would need a sub with a low pass freq. confused, so i came here to the real experts. thanks
Post edited by Neale13 on
  • codyc1ark
    codyc1ark Posts: 2,539
    edited November 2012
    You should have two sets of speaker inputs on the back of your sub. Run your wire from the amp, to the sub, and then out of the other speaker inputs to the speakers. MOST subs have the speaker wire option, but not all. Which sub are you looking at?
  • Neale13
    Neale13 Posts: 88
    when you say run wire from amp do you mean rca jacks? because my speaker wire from my amps goes directly to my towers
  • Neale13
    Neale13 Posts: 88
    my pre amp is a rotel rc 1070
  • Neale13
    Neale13 Posts: 88
    sub i am thinking of getting is polk dsw 660wi
  • classic carl
    classic carl Posts: 676
    Neale, you are correct. The guy at Best Buy and the guy at Crutchfield do not know what they are talking about. You can connect a Y-splitter from either output on your preamp and run RCA cables to your sub and your power amp. It's that simple. You can adjust the crossover on the sub to your preference. I also have two outputs on my Yamaha C-4 preamp. One output is connected to my power amp and the other is connectd to my sub. You could add a second sub by splitting each output if you wish.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
    Teac R-919X ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • BigGilles
    BigGilles Posts: 6
    second sub the best way
    or an other pre-amp,
    for speaker hook-up
    my last option :sad:
    keep up the good work !
  • SDA1C
    SDA1C Posts: 2,072
    I have found that Cody's suggestion lends the best (to my ears) sound when using a pre with no sub out. Run the speaker wires to the sub and then from the sub to the mains.
    Too much **** to list....
  • Tbone289
    Tbone289 Posts: 661
    SDA1C wrote: »
    That has always sounded best to me also. However, I prefer to just run two sets of speaker wires directly from the amp's output. One set to the mains, the other set to the sub. I figure that will eliminate any possibility of "coloration" the sub connections might impart to the mains signal. The amp won't care, because the sub's input impedance is very high, so it will have virtually no effect on the current requirement.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • classic carl
    There are many ways to skin a cat. The reason that I connect mine as I do is because my preamp has two sets of outputs and there are two switches on the front to turn each of them on or off independently. I can turn off the output to my mains and listen only to the sub, which helped immensely when I was dialing the sub in. It also comes in handy when a recording is too bass heavy. I just turn the sub output off. I also have a single input passive pre between my sub output and the sub to control the volume without having to reach behind the sub for adjustment.
    The OP mentioned using RCA cables, which is why I answered as I did. At least we here all know more than the so-called "experts" at BB or Crutchfield, who are actually paid to know this information.
    Main System 2.2:
  • SDA1C
    SDA1C Posts: 2,072
    Does the sub with the line level ins and outs filter the out after it feeds the sub. I would think using 2 sets of wires, one to the sub and one the mains, would negate this effect.
    I am fairly certain a bucket of ****, missing a handle, knows more on average than the typical big box retail associate.
  • Tbone289
    Tbone289 Posts: 661
    The OP mentioned using RCA cables, which is why I answered as I did. At least we here all know more than the so-called "experts" at BB or Crutchfield, who are actually paid to know this ****.
    Indeed. All three of our answers are "correct", as far as I'm concerned. I suggest trying all options and use whatever sounds best.
  • Tbone289
    Tbone289 Posts: 661
    SDA1C wrote: »
    No. Most subwoofers (including all Polk models) have a low pass filter--not a crossover. The low pass filter blocks frequencies above the setpoint sent to the subwoofer, but doesn't alter the frequency spectrum sent from the output to the mains. Your method of connection and mine will both result in the entire signal being sent to the mains.
  • 20hz
    20hz Posts: 636
    if you want all adjustment at your fingertips look at a energy EAC electronic crossover it has both preamp plugs and a internall convertor so you can hook up speaker wires to it than to the amps
  • Tbone289
    Tbone289 Posts: 661
    reported
