OWM3 Thread Size
rodelperezph
Hi Guys,
I need your help.
I'd like to mount my OWM3 using wall/ceiling speaker brackets and I'd like to use the thread at the back.
May i ask if anyone knows the thread size?
Thanks!
Regards,
Rodel
I need your help.
Thanks!
Regards,
Rodel
Denon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
Post edited by rodelperezph on
Hello Rodel,
That is 1/4" diameter #20 thread size.
Regards, Ken -
Hi Ken,
Do you think this will fit?
OmniMount 5.0 W/C
Specs...
Fits most: Satellite speakers
Supports up to: 5 lbs (2.3 kg)
Thread size: 4mm or 5mm
Tilt: +/-30?
Pan: 180?
Base Rotation: 360?
Color: Black
Thanks!
Regards,
RodelDenon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub -
4 or 5mm will NOT fit a 1/4 20 thread.
Hi Rodel,
No that one won't work, you need the 10.0 series from Omnimount.
Regards, Ken -
Hi Chumlie and Ken,
Thank you so much for this information!
Regards,
RodelDenon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub -
No problem, glad to be of help!
Ken,
By the way, what other brands can you suggest?
Thanks!
Regards,
RodelDenon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
