Need help using kenwood KR-5600 tuner section only
laotzu61
laotzu61 Posts: 327
edited November 2012 in Electronics
i am in the process of connecting my onkyo m-504 to a hafler dh-101 preamp along with the cd player and turntable. i would like to connect the kenwood kr-5600 receiver to utilize the tuner section only. i have renoved the jumpers on the kenny. what do i connect on the kenny to "tuner" on the preamp, please?
thanks for any help, and have a great thanksgiving all of you!! :wink:
"The symbol is not the reality"
Post edited by laotzu61 on
    F1nut Posts: 51,778
    You can't do that.
  • laotzu61
    laotzu61 Posts: 327
    thanks for the response. i have another question. why would i be able to use the kenwood as a preamp, but not as a "tuner" only? i'm asking because i don't know. learning curve, here. thanks.
    Didn't we already deal with this in another thread?
    As far as trying to use the kenwood tuner, you might be able to use a tape monitor loop, but the quality might be iffy.
    Briefly. Connect your Hafler to the Onkyo then, assuming the Hafler has a tape IN, select that source on the Hafler. Run the TAPE MONITOR OUTS on the Kenwood the the INS on the Hafler. Then select TAPE MONITOR "ON" on the Kenwood while you also select FM-Stereo as the output from the Kenwood. Theoretically that should send the FM signal to the Tape so it could be recorded by the tape deck. But in this case there is NO tape deck just the input to the Hafler.
    Give that a try.
    And then have a beer, eat some turkey and watch a little football. H-T-Giving!
    cnh
  • halo71
    halo71 Posts: 4,632
    Mainly because your Kenwood does not have a dedicated tuner output. I am assuming you think the Hafler preamp sounds better than the Kenwood? You need to find a dedicated tuner though. If you are interested I have an old digital Onkyo tuner I no longer use.
    --Gary--
  • laotzu61
    laotzu61 Posts: 327
    thanks for the offer on the tuner, gary; for better or worse, i'm a vintage analog junkie. (cd player an exception) the jury is still out on the hafler vs. kenwood as a preamp, as they do sound different. i think i need to listen thru the hafler more at this point. the kenwood sounded "brighter" but i hear more thru the hafler, if that makes any sense. i also want to get the hafler re-capped, etc. i know it's a very good preamp, and i got it for a very good price. just need to get used to it. in any event, the kenwood's always got a home. thanks again.
