Mmc4
Systems
Systems Posts: 14,872
edited July 2004 in Car Subwoofer Talk
Hello, does anyone have any info on how to get the Polk subs to replace the originals in a Polk C4 bandpass box?
I put 2 kicker comp's in, and they sound fine, but don't hit nearly as low as the original speakers did. Also, due to the magnet depth, I could only use two in the inner (push) chamber.
I still have the original speakers, but they pop and crack violently due to sheer wear and age, particularly the "pull" drivers.
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited May 2004
    bandpass boxes must be tuned for the particular driver's they've got in them. so im not surprised the kickers don't work so good. perhaps just make a new box suited to your new drivers?
  • exalted512
    exalted512 Posts: 10,734
    edited May 2004
    i thought the c4 used 6x9s??
    -Cody
  • neomagus00
    edited May 2004
    yeah, they did... ???
  • Systems
    edited July 2004
    Yes, the sub box does use 6X9's.
    I am using a set of 6x9 Kicker subwoofers (they no longer make these). You can occasionally find these on Ebay in new-old stock auctions.
    It actually sound godd, except that the frequency response of the Kickers are rated at a low of 30hz, and the original Polk subwoofers were rated to 25hz. In reality, the Kickers probably cut about 40hz however, as I discovered from using a bass test disc, while the Polks go down to an honest 25hz.
    I really prefer a sub system that can go down to 20hz or pretty close to it!
    Unfortunately, all 4 Polks are junk, due to the fact they are 10 years old (appx.). They all still play, but pop and crack, as I mentioned before.
    I just wish there was a way to replace with the originals, particularly since they are the correct speakers for the box.
    Also, any of you guys out there that have heard a C4 know how impressive they sound, especially considering the size / weight.
    Testing
    Testing
    Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2004
    You may be better off retiring the bandpass and getting new subs and building a new box. ;)
