Low batteries in DTV remote created weird Surround Bar 6000 problem
gdmedia
gdmedia Posts: 5
edited November 2012 in Troubleshooting
I had a Polk Surround Bar 6000 installed on the wall under our new Sharp TV, in mid-September. We have DirecTV (DTV) and I synced the Bar with the DTV remote. All worked well, at first. But pretty soon, the Sound Bar started exhibiting an intermittent problem: sometimes when I would attempt to change TV channels using the DTV remote, the Sound Bar would stop working. No sound. I tried everything I could think of but the problem kept happening, about once or twice a night. I finally found that I could get the sound back by turning the Sound Bar off and back on. But then, I would have to re-adjust the sub volume using the Polk remote.
I called Polk a couple of times and talked with tech reps, who were very helpful but only came to the same conclusion that I had come to -- that something must be wrong with the Sound Bar. We made arrangements for me to send it back to Polk in California for replacement. But then I was enlightened.
Then, during the process of trying to reproduce the problem for someone, the batteries on the DTV remote went completely out. I had noticed that the response of the TV to the remote had been slow sometimes recently but it had not been enough of a problem to cue me that my remote batteries were weak. Anyway, I replaced the batteries in the remote. And the Surround Bar problem just stopped happening. (The response of the TV to the remote picked up nicely, as well.)
I delayed sending the Sound Bar back to Polk to see if the problem had been fixed -- and it had. Now, after 6 weeks have passed, I have never had any problem again. The Sound Bar works perfectly!
So, apparently, the problem was that weak batteries in my DTV remote caused the channel-change signal to the TV to somehow tell the Sound Bar to turn itself off. And nobody at Polk thought of this possibility. Nor did I or my installer -- until the batteries went completely dead and were replaced, fixing the problem.
One of these days, this will happen to somebody else. Maybe they'll find this posting.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Good to Know, and something Polk techs should know.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • BlueFox
    BlueFox Posts: 15,250
    All my remotes over the years act weird when the batteries are low.
