Turntable clipping at higher volume?
Dabutcher
Dabutcher Posts: 2,604
edited November 2012 in Electronics
My best turntable has been in my garage set up all summer hooked directly to a Nad integrated. Now that it is getting cold out. I no longer hang out in the garage so I moved TT back in to main HT set up w Marantz and a BBE Phono pre. Now I get a hum or clip at higher volumes? I do not know of doing anything differently than last spring when I last had it hooked up. Ground wire from TT is hooked up to phono pre. My fronts are now SDA SRS and I used my RTi 12's before? Thanks in advance. Darryl
Post edited by Dabutcher on
  • Msabot1
    Msabot1 Posts: 2,098
    No noise in other location? Doesn't sound like a ground fault,you would hear that at any volume. What power supply turns your platter?
    if not DC then it's AC line noise,not sure but I'd check that first.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    Could it be vibration affecting the tonearm at higher listening levels?
    SDA SRS 2.3TL's
    SDA 2B TL's
    SCompRacer Posts: 9,112
    I'd go along with this according to what has been presented. I'll bet the bass is better with them SDA SRS.:wink:
    A turntable is a mechanical pickup system. The sensitivity of a turntable to vibration depends upon the room acoustics, the turntables location in the room, and how it is supported. Isolation is great for floor/rack vibrations but the table is still susceptible to airborne vibes. You may have to experiment with isolation or relocating the table. I would do that before thinking of trying a subsonic/rumble filter.
    EDIT:
    BTW I've experienced what I described with my rig. If I do a south wall setup with the table between the speakers, there is no playing vinyl above 75dB SPL. Table and gear on side wall, I can go to over 100dB SPL and lose some hearing.:cheesygrin:
  • Msabot1
    Good point! Db will have an effect on pickup,especially at higher pressure levels,feedback,vibration,ect.
  • Dabutcher
    Makes a lot of sense too me since TT is placed right in front of passive on SDA's. I will check it out tonight thanks for the help. Darryl
  • Dabutcher
    That was the problem. moved it away from front of speaker and sounds great at high volumn. thanks as always,Darryl
  • michaeljhsda2
    Cool Y W
    SDA SRS 2.3TL's
    SDA 2B TL's
