Need some help on surround choices
Stocks_sd
Hey everybody.
First time posting in the forums and I'm hoping to get some opinions on what surround speakers I should buy. Here's what I have so far.
Harman/Kardon avr310
rt800i's (front)
cs245i (center) upgrading to cs400i
rt25i's (surround)
Panasonic RP56
Here's the problem. I went in to Circuit City to upgrade my 25i's to fx500i's and they were sold out along with the two other stores in my area. They can't order them anymore so I'm going through my other options. Rt35i's, rt55i's, or fx300i's. I'm leaning towards the fx300i's but I'm not sure if I'll be happy with them. If I do go with the 300i's I was thinking about keeping my 25i's for a 7.1 system later on. Any thoughts?
rt800i's (front)
rt25i's (surround)
Panasonic RP56
Post edited by RyanC_Masimo on
i would use the 25i for the rear channel speakers, they deserve a listen frist before you buy someting else. i like the rt-35i for surounds if you can find them. wecome to the polk forum. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
Your set up is very similar to mine!
HK AVR310
cs400i- center
rt800i- main
rt35i- rear
everything is working out nicely!.......however, you may want to pick up a sub later on in time....it adds the extra deep lows for your music listening and for the special effects while watching DVD'S.
dc.:D -
I have psw450 for my sub. Forgot to put that on my list.
rt35i's for side surrounds with rt25i's as center surrounds work great(i would like f/x500's, but can't get them). i just have mine at 5.1, but 7.1 is coming soon... i think the rt35i's or rt55i's are a better choice cause they mate with the tweeter's that you have in your current system(even though the dipoles are suggested as side surrounds). any way you can bring them all home and listen to each in your space???
I bought the 35I's Tuesday and tried them as rear surrounds mounted on the rear wall. After a lot of testing Tuesday night, I took them back Wednesday and got the 300I's. I'm not a tech person, but for me at least, the 300I's provided a more expansive surround enviroment while listening to DD/DTS material. The 35I is a nice speaker, and used as a side surround it may be fantastic. It just did'nt work for me mounted on the rear wall. I also have the 800's, 350 sub, and by all means, get the 400 center. That in itself will make a world of difference in your system. Good luck!
Ron
